Me Ducer
Me Ducer is the sixth gerneration of desktop 3D printer made by Geeetech, it is a portable cantilever type 3D printer with two handles, suitable for any place like home, office, lab, or classroom. To increase the stablity of cantilever type design, Me Ducer adopts 12mm-diameter superior hardness, wear resistance, oxidation resistance and carbon steel bearings for Y and Z axis, effectively avoiding vibrations during printing and making it more accurat for the positioning of Y and Z axis. In addition, we add a manually adjusting knob on the top of the machine which is used for the fine-tuning of Z axis.
As the companion piece of the Me Creator , Me Ducer continues with its overall look of solemnity and high-quality, but the high gloss piano black finished acrylic chasis adds even more panache and elegance to Me Ducer. Besides the consideration of art and aesthetics, 8mm industrial-strength acrylic chasis ensures incredible strength and durability.
Compared to its predecessors, the extruder of Me Ducer is no longer exposed barely, instead, we add a hood to cover the extruder which is crafted out of high-quality steel. So is the main control system, which is built in the base case. On one hand, it looks good and on the other hand, it offers a large degree of protection to the kids or pets from the high temprature of the extruder, creating a safer and more comfortable printing experience.
- No assembly required, plug-and-play.
- Make high-resolution printing objects.
- Brand new look. Suitable for home, office, lab, or classroom.
- 8mm -thickness gloss piano black acrylic chasis for strength and durability.
- 12mm-diameter steel bearings for more accurate positioning.
- In- built control system, extending service life.
- Compatible with Mac/Linux/Windows.
- With LCD control panel, support off-line printing.
- SD Card Reader support
- With Heatbed, both PLA and ABS are printable
- Compact and portable, easy to be carried
See more tetails
filament spool -
fine-tuning knob -
SD card slot -
handle and bearing -
Aircraft-grade aluminum print plate
Printing
Print Technology: Fused Filament Fabrication(FFF)
Build Volume: 180 x 150 x 150mm
Layer Resolution: 0.1-0.3mm
Position accuracy of X/Y axis: 0.01mm
Position accuracy of Z axis: 0.005 mm
Filament Type:ABS/ PLA
Filament Diameter: 1.75 mm
Nozzle Diameter: 0.4 mm
Software: Repetier-Host,Printrun
File Types: .stl
Supports: Windows/Mac/Linux
Temperature
Eectrical
Power Input: 100-120VAC/4.8A or 200-240VAC/2.4
Power output:DC12V/ 29A
Support heatbed: Yes
Mechanical
Body: high strength and hardness Industrial-strength Acrylic
Build Platform: Aircraft-grade aluminum
XYZ Bearings: carbon steel
Physical structure: Cantilever type
Physical Dimensions
Machine Dimensions: 300 x 300x370(mm)
Machine weight (Net weight): 10 kg
Print Plate Size (Build Platform): 180x155x3mm
Install the drivers
Installing Drivers Before printing, you’ll need to install drivers. The kind of driver that a Me Ducerrequires in order to operate properly is called a USB Serial Driver. A USB Serial Driver is software that establishes a COM port.
Windows 8
Windows Manual Install
To install all required software by Me Ducer, please follow the steps provided below.
3) Open Repetier Host and Connect to your Me Ducer!
Me Ducer -
Me Ducer -
Me Ducer -
Me Ducer
where to buy
Please click here
