Me Ducer
Me Ducer is the sixt h gerneration of desktop 3D printer made by Geeetech, it is a portable cantilever type 3D printer with two handles, suitable for any place like home, office, lab, or classroom. To increase the stablity of cantilever type design, Me Ducer adopts 12mm-diameter superior hardness, wear resistance, oxidation resistance and carbon steel bearings for Y and Z axis, effectively avoiding vibrations during printing and making it more accurat for the positioning of Y and Z axis. In addition, we add a manually adjusting knob on the top of the machine which is used for the fine-tuning of Z axis.
As the companion piece of the Me Creator , Me Ducer continues with its overall look of solemnity and high-quality, but the high gloss piano black finished acrylic chasis adds even more panache and elegance to Me Ducer. Besides the consideration of art and aesthetics, 8mm industrial-strength acrylic chasis ensures incredible strength and durability.
Compared to its predecessors, the extruder of Me Ducer is no longer exposed barely, instead, we add a hood to cover the extruder which is crafted out of high-quality steel. So is the main control system, which is built in the base case. On one hand, it looks good and on the other hand, it offers a large degree of protection to the kids or pets from the high temprature of the extruder, creating a safer and more comfortable printing experience.
- No assembly required, plug-and-play.
- Make high-resolution printing objects.
- Brand new look. Suitable for home, office, lab, or classroom.
- 8mm -thickness gloss piano black acrylic chasis for strength and durability.
- 12mm-diameter steel bearings for more accurate positioning.
- In- built control system, extending service life.
- Compatible with Mac/Linux/Windows.
- With LCD control panel, support off-line printing.
- SD Card Reader support
- With Heatbed, both PLA and ABS are printable
- Compact and portable, easy to be carried
See more tetails
filament spool -
fine-tuning knob -
SD card slot -
handle and bearing -
Aircraft-grade aluminum print plate
Printing
Print Technology: Fused Filament Fabrication(FFF)
Build Volume: 180 x 150 x 150mm
Layer Resolution: 0.1-0.3mm
Position accuracy of X/Y axis: 0.01mm
Position accuracy of Z axis: 0.005 mm
Filament Type:ABS/ PLA
Filament Diameter: 1.75 mm
Nozzle Diameter: 0.4 mm
Software: Repetier-Host,Printrun
File Types: .stl
Supports: Windows/Mac/Linux
Temperature
Eectrical
Power Input: 100-120VAC/4.8A or 200-240VAC/2.4
Power output:DC12V/ 29A
Support heatbed: Yes
Mechanical
Body: high strength and hardness Industrial-strength Acrylic
Build Platform: Aircraft-grade aluminum
XYZ Bearings: carbon steel
Physical structure: Cantilever type
Physical Dimensions
Machine Dimensions: 300 x 300x370(mm)
Machine weight (Net weight): 10 kg
Print Plate Size (Build Platform): 180x155x3mm
Install the drivers
Installing Drivers Before printing, you’ll need to install drivers. The kind of driver that a Me Ducerrequires in order to operate properly is called a USB Serial Driver. A USB Serial Driver is software that establishes a COM port.
Windows 8
Windows Manual Install
Macbook Manual Install
To install all required software by Me Ducer, please follow the steps provided below.
3) Open Repetier Host and Connect to your Me Ducer!
Me Ducer -
Me Ducer -
Me Ducer -
Me Ducer
How to control on LCD
- Press the button>”Prepare”>”Move axis”>”Move 10mm/1mm/0.1mm”>”Move X/Y/Z/extruder”
where to buy
Please click here
