Real Time Clock RTC DS1307 Module
DESCRIPTION
FEATURES
  • Real-time clock (RTC) counts seconds,minutes, hours, date of the month, month, daof the week, and year with leap-year compensation valid up to 2100
  • 56-byte, battery-backed, nonvolatile (NV) RAM for data storage
  • Two-wire serial interface
  • Programmable squarewave output signal
  • Automatic power-fail detect and switch circuitry
  • Consumes less than 500nA in battery backup mode with oscillator running
  • Optional industrial temperature range:-40°C to +85°C
  • Available in 8-pin DIP or SOIC Underwriters Laboratory (UL) recognized
PIN DESCRIPTION
VCC - Primary Power Supply
GND - Ground
