Real Time Clock RTC DS1307 Module
  • Real-time clock (RTC) counts seconds,minutes, hours, date of the month, month, daof the week, and year with leap-year compensation valid up to 2100
  • 56-byte, battery-backed, nonvolatile (NV) RAM for data storage
  • Two-wire serial interface
  • Programmable squarewave output signal
  • Automatic power-fail detect and switch circuitry
  • Consumes less than 500nA in battery backup mode with oscillator running
  • Optional industrial temperature range:-40°C to +85°C
  • Available in 8-pin DIP or SOIC Underwriters Laboratory (UL) recognized
Pin Description
VCC - Primary Power Supply
GND - Ground
DS1307 Library 1
DS1307 Library 2
DS1307 datasheet
DS1307 Usage
Download the DS1307 Library then uncompress DS1307 Library into "libraries" folder of Arduino and restart ;
Testcode
#include <WProgram.h>
#include <Wire.h>
#include <DS1307.h> written by mattt on the Arduino forum and modified by D. Sjunnesson
RTC.stop();
RTC.set(DS1307_SEC,1); set the seconds
RTC.set(DS1307_MIN,23); set the minutes
RTC.set(DS1307_HR,12); set the hours
RTC.set(DS1307_DOW,4); set the day of the week
RTC.set(DS1307_DATE,15); set the date
RTC.set(DS1307_MTH,7); set the month
RTC.set(DS1307_YR,10); set the year
RTC.start();
Serial.print(RTC.get(DS1307_HR,true)); read the hour and also update all the values by pushing in true
Serial.print(":");
Serial.print(RTC.get(DS1307_MIN,false));read minutes without update (false)
Serial.print(":");
Serial.print(RTC.get(DS1307_SEC,false));read seconds
Serial.print(" "); some space for a more happy life
Serial.print(RTC.get(DS1307_DATE,false));read date
Serial.print("/");
Serial.print(RTC.get(DS1307_MTH,false));read month
Serial.print("/");
Serial.print(RTC.get(DS1307_YR,false)); //read year
Serial.println();
delay(1000);
Click here to buy DS1307 module
