Building Instructions of Geeetech Prusa I3 X
Revision as of 07:21, 18 November 2015 by Admin (talk | contribs) (12.Fan mount)
Preparation
  • All the acrylic plates have been etched with part ID and the plate is covered with a sheet of kraft paper, you need to tear them off.
450mm threaded rod
No.5
2
M10 washer
No.9
8
M10 hex nut
No.13
8
M10 spring washer
No.10
6
Connecting fender
No.A14
2
Watch the Video here.
M10 washer
No.9
4
M10 hex nut
No.13
4
Y axis front support
No.A9
1
No.A10
1
Y axis rear support
No.A11
1
Y axis rear support
No.A12
1
(this picture is just for reference, the plates are not exactly the same as that for I3 X)
  • Tips:
You can watch the video here.
3.Mount the Y motor
stepper motor
No.63
1
Y motor holder
No.A13
1
M3 x12mm screw
No.22
3
M3 x 20mm screw
No.24
2
M3 square nut
No.16
2
Pulley
No.42
1
Fix the holder plate with 2 M3 x 20mm screws and M3 square nut.
4.Y belt driving wheel
Driven wheel holder
No.40
1
Driving wheel
No.40A
1
Ball Bearing
No.35
2
M3 x20mm screw
No.24
3
M4 x 25mm screw
No.31
2
M4 locking nut
No.14
2
wing nut
No.15
1
Step 1. Thread the M3 x 20 screw through the top hole on the drive wheel holder.
Step 2. Pick up 2 MR84zz ball bearings. Insert 1 MR84zz ball bearings into both ends of the drive wheel .
Step 3.Place the drive wheel in to the drive wheel holder and fix it in place with an M4 x25 screw and M4 washer. Lock the other end with a M4 lock nut . You may need a wrench to tighten M4 locking nut.
  • Note: Do not screw it too tightly as it may restrict the free movement of the drive wheel. It is important that you leave enough room for the wheel to turn freely.
5. Build the print platform
Building platform support
No.A15
1
Belt mount
No.41
1
M4 x 16mm screw
No.30
16
M4 washer
No.8
16
SCS8UU linear bearing
No.36
4
M3 x12mm screw
No.22
2
M3 washer
No.7
2
6. Mount the Y belt
Timing belt
No.39
1
M3 x8mm screw
No.21
2
M3 washer
No.7
2
  • Tips:
2. Loosen the Y idler wing nut when tightening belt onto the Y belt mount [No. 67] in order to make securing the belt to the block easier. Be sure to tighten wing nut fully  once done.
Watch the video here.
7.Left Z motor mount
M2.5 hex nut
No.11
2
M2.5x16mm screw
No.20
2
M3 x 16mm screw
No.23
3
M3 Square nut
No.16
3
end stop
No.52
1
Motor holder (left)
No.A4
1
Motor Holder support
No.A6
1
No.A7
1
Z endstop mount
No.A28
1
Step 1. Mount the endstop(No.52) on the endstop mount (No.A28) with two M2.5 x 16mm screws and nut.
8.Right Z motor mount
M3 x 16mm screw
No.23
2
M3 Square nut
No.16
2
Motor holder (right)
No.A5
1
No.A6
1
No.A7
1
Assemble the right motor holder (No.A5) and the motor holder support (No.A6 and No.A7) together, screw it up with 2 M3 x 16mm screw and M3 Square nut.
M3 x 16mm screw
No.23
6
M3 Square nut
No.16
6
Main frame
No.A1
1
10.Side panel assembly
M3 x 16mm screw
No.23
6
M3 Square nut
No.16
6
M3 washer
No.7
6
Side panel(left)
No.A2
1
Side panel(right)
No.A3
1
11.Main frame assembly
M3 x 16mm screw
No.23
2
M3 x 20mm screw
No. 24
4
M3 hex nut
No.12
4
M3 square nut
No.16
6
M3 washer
No.7
4
Step 1. Thread the assembled Y axis into the main frame(A1), put the main frame between the Connecting fender and the M10 nut. The Connecting fender is at the front part of the Y axis.
Step 2. Connect the side panel to the rear support plate, screw it up with M3 x 16mm screw and M3 square nut.
Step 3. Fix the connecting fender to A1 with M3 x 20mm screw and M3 hex nut.
12.Fan mount
M3 x 25mm screw
No. 25
4
M3 hex nut
No.12
4
Fan
No.56
1
Mount the fan on the left back side of the A1.
Step 1. Mount the Z-axis nut.
M3 x 16mm screw
No. 23
4
M3 washer
No. 7
4
Z-axis nut
No.17
1
Left bearing bottom plate
No.A18
1
Mount the Z nut on the A 18 from bottom to up, fix with M3 x 16mm screw and M3 washer.
M3 x 30mm screw
No. 26
2
M3 x 50 screw
No.28
1
M3 hex nut
No. 12/center>
4
Spring
No.34
1
Endstop holder
No.A21
1
Endstop holder
No.A22
1
Step 3. Mount the endstop
M2.5 x 16mm screw
No. 20
2
M2.5 hex nut
No. 11
2
End stop
No.52/center>
1
Left bearing top plate
No.A17
1
M3 x 16mm screw
No. 23
8
M3 Square nut
No. 16
8
X motor holder
No.A 16/center>
1
X axis rod holder (left)
No.A 19
2
X axis belt holder
No.A 20
1
No. 37
1
M4x16mm screw
No. 30
4
M3 x 16mm screw
No. 23/center>
4
M3 Square nut
No. 16
4
M3 x 16mm screw
No. 23
4
M3 washer
No. 7
4
Z-axis nut
No.17/center>
1
Right bearing top/bottom plate
No.A24
1
M3 x 16mm screw
No. 23
4
M3 Square nut
No. 16
4
Right bearing holder
No.A23
1
X axis rod holder(right)
No.A25
1
X axis driving wheel support holder
No.A26
1
M3 x 16mm screw
No. 23
4
M3 Square nut
No. 16
4
No.A23
1
No. 37
1
M4x16mm screw
No. 30
4
stepper motor
No.63
3
M3 x12mm screw
No.22
12
Pulley
No.42
1
Mount the X motor
Mount the Z motor
M3 x 16mm screw
No.23
6
M3 Square nut
No.16
6
M3 washer
No.7
10
M3x12mm screw
No.22
2
M3 hex nut
No.12
2
belt mount
No.41
1
X axis bearing support plate
No.A 29
1
Extruder Bracket
No.A30
1
extruder bracket support
No.A31
2
SCS8UU Linear Bearing
No.36
3
M4x16mm screw
No. 30
12
Extruder
No. 61
1
M4x12mm Screw
No.29
1
17. X belt driving wheel
Driven wheel holder
No.40
1
624zz Ball Bearing
No.35
2
M3 x50mm screw
No.28
3
M4 x 25mm screw
No.31
2
M4 locking nut
No.16
2
wing nut
No.42
1
Step2. Put the M4 x25 screw through the holes with the two 624ZZ bearings in between. Lock the other end with a M4 lock nut. You may need a spanner to tighten locking nut.
L430mm smooth rod
No.2
2
locking ring
No.35
2
X axis Fender
No.A27
2
Add the belt
Timing belt
No.39
1
M3 x8mm screw
No.21
1
M3 washer
No.7
1
500px
  • Tips:
19. Assemble the X axis on the printer
L322mm smooth rod
No.1
2
300mm threaded rod
No.4
2
Coupling
No.38
2
Z top mount
No.A8
2
M3 x 16mm screw
No.23
6
M3 Square nut
No.16
6
locking ring
No.32
2
Building platform
No.44
1
Heatbed set
No.53,54,55
1
wing nut
No.42
4
Hex Counter-sunk-head screw
No.19
4
Spring
No.33
4
23.Mount the LCD panel
LCD 2004
No.64
1
Knob
No.65
1
Spacer
No.50
4
M3 x 12mm screw
No.22
4
Do not mix them up.
Here you can watch the video.
Power supply Unit
No.58
1
3D Power Cable
No.60
1
M3 x 12mm screw
No.22
4
No.18
2
M3 hex nut
No. 2
2
25.Mount the control board.
Control board kit
No.62
1
Sticker
No.47
1
Heat sink
No.48
1
Spacer
No.50
4
M3 x 12mm screw
No.22
4
Here is the video.
26.Wiring
File:15 y motor1.jpg
File:15 z motor1.jpg
4) Connect Extruder motors
Connect extruder 1.
Step4. Connect heating wires.
Step7. Connect wires for Fan.
EXP1 to SD card
EXP2 to LCD
Brown------L
Blue ------N
Yellow------GND
Red ------ -- + V
Black------COM
27.Mount the filament spool
M3 x 16mm screw
No.23
6
M3 Square nut
No.16
6
M3 washer
No.7
6
Spool base plate
1
Spool side pane
2
PVC tube
1
PVC tube
2
  • Each machine may have its own calibration procedure and this manual will not attempt to cover all the variations. Instead here is a list of key points that should be addressed.
  • Belts are taut.
  • Firmware settings are correct including: axis movement speeds and acceleration; temperature control; end-stops; motor directions.
  • Extruder is calibrated in the firmware with the correct steps per mm of filament.
