Building Instructions of Geeetech Prusa I3 X
Preparation
  • All the acrylic plates have been etched with part ID and the plate is covered with a sheet of kraft paper, you need to tear them off.
450mm threaded rod
53
2
M10 washer
33
8
M10 hex nut
A3
8
M10 spring washer
A4
6
Connecting fender
14
2
M10 nut <M10 nut < M8 spring washer<M10 washer in turn on the left
3) Thread theM10 washer < M8 spring washer < M10 nut < M10 nut< M8 spring washer < M10 washer in turn on the right
Watch the Video here.
M10 washer
No.9
4
M10 hex nut
No.13
4
Y axis front support
No.A9
1
No.A10
1
Y axis rear support
No.A11
1
Y axis rear support
No.A12
1
  • Tips:
You can watch the video here.
3.Mount the Y motor
stepper motor
No.63
1
Y motor holder
No.A13
1
M3 x12mm screw
No.22
3
M3 x 16mm screw
No.23
2
M3 square nut
No.16
2
Pulley
No.42
1
Fix the holder plate with 2 M3 x 16 screws and M3 square nut.
4.Y belt driving wheel
Driven wheel holder
No.40
1
624zz Ball Bearing
No.35
2
M3 x20mm screw
No.24
3
M4 x 25mm screw
No.31
2
M4 locking nut
No.16
2
wing nut
No.42
1
Step1. Thread the M3 x 20 screw through the bearing holder.
Step2. Put the M4 x25 screw through the holes with the two 624ZZ bearings in between. Lock the other end with a M4 lock nut. You may need a spanner to tighten locking nut.
5. Build the print platform
Building platform support
No.A15
1
Belt mount
No.41
1
M4 x 16mm screw
No.30
16
M4 washer
No.8
16
SCS8UU linear bearing
No.36
4
M3 x12mm screw
No.22
2
M3 washer
No.7
2
6. Mount the Y belt
Timing belt
No.39
1
M3 x8mm screw
No.21
2
M3 washer
No.7
2
  • Tips:
2. Loosen the Y idler wing nut when tightening belt onto the Y belt mount [No. 67] in order to make securing the belt to the block easier. Be sure to tighten wing nut fully  once done.
Watch the video here.
7.Left Z motor mount
M2.5 hex nut
No.11
2
M2.5x16mm screw
No.20
2
M3 x 16mm screw
No.23
3
M3 Square nut
No.16
3
end stop
No.52
1
Motor holder (left)
No.A4
1
Motor Holder support
No.A6
1
No.A7
1
Z endstop mount
No.A28
1
Step 1. Mount the endstop on the endstop mount with two M2.5 x 16screws and nut.
8.Right Z motor mount
M3 x 16mm screw
No.23
2
M3 Square nut
No.16
2
Motor holder (right)
No.A5
1
No.A6
1
No.A7
1
Assemble the motor holder ((right) and the motor holder support together, screw it up with 3 M3 x 16mm screw and M3 Square nut.
M3 x 16mm screw
No.23
6
M3 Square nut
No.16
6
Main frame
No.A1
1
10.Side panel assembly
M3 x 16mm screw
No.23
6
M3 Square nut
No.16
6
M3 washer
No.7
6
Side panel(left)
No.A2
1
Side panel(right)
No.A3
1
11.Main frame assembly
M3 x 16mm screw
No.23
2
M3 x 20mm screw
No. 24
4
M3 hex nut
No. 2
4
M3 square nut
No.16
6
M3 washer
No.7
4
Step 1. Thread the assembled Y axis into the main frame(A1), put the main frame between the Connecting fender and the M10 nut. The Connecting fender is at the front part of the Y axis. Step 2. Connect the side panel to the rear support plate, screw it up with M3 x 16mm screw and M3 square nut. Step 3. Fix the connecting fender to A1 with M3 x 20mm screw and M3 hex nut.
12.Fan mount
M3 x 25mm screw
No. 25
4
M3 hex nut
No. 2
4
Fan
No.56
1
Mount the fan on the left side of the A1. Watch the video here.
Step 1. Mount the Z-axis nut.
M3 x 16mm screw
No. 23
4
M3 washer
No. 7
4
Z-axis nut
No.17
1
Left bearing bottom plate
No.A18
1
Mount the Z nut on the A 18 from bottom to up, fix with M3 x 16mm screw and M3 washer.
M3 x 30mm screw
No. 26
2
M3 x 50 screw
No.28
1
M3 hex nut
No. 12/center>
4
Spring
No.34
1
Endstop holder
No.A21
1
Endstop holder
No.A22
1
Step 3. Mount the endstop
M2.5 x 16mm screw
No. 20
2
M2.5 hex nut
No. 11
2
End stop
No.52/center>
1
Left bearing top plate
No.A17
1
M3 x 16mm screw
No. 23
8
M3 Square nut
No. 16
8
X motor holder
No.A 16/center>
1
X axis rod holder (left)
No.A 19
2
X axis belt holder
No.A 20
1
  • Note the direction
No. 37
1
M4x16mm screw
No. 30
4
M3 x 16mm screw
No. 23/center>
4
M3 Square nut
No. 16
4
M3 x 16mm screw
No. 23
4
M3 washer
No. 7
4
Z-axis nut
No.17/center>
1
Right bearing top/bottom plate
No.A24
1
M3 x 16mm screw
No. 23
4
M3 Square nut
No. 16
4
Right bearing holder
No.A23
1
X axis rod holder(right)
No.A25
1
X axis driving wheel support holder
No.A26
1
M3 x 16mm screw
No. 23
4
M3 Square nut
No. 16
4
No.A23
1
No. 37
1
M4x16mm screw
No. 30
4
stepper motor
No.63
3
M3 x12mm screw
No.22
12
Pulley
No.42
1
Mount the X motor
Mount the Z motor
M3 x 16mm screw
No.23
6
M3 Square nut
No.16
6
M3 washer
No.7
10
M3x12mm screw
No.22
2
M3 hex nut
No.12
2
belt mount
No.41
1
X axis bearing support plate
No.A 29
1
Extruder Bracket
No.A30
1
extruder bracket support
No.A31
2
SCS8UU Linear Bearing
No.36
3
M4x16mm screw
No. 30
12
Extruder
No. 61
1
M4x12mm Screw
No.29
1
17. X belt driving wheel
Driven wheel holder
No.40
1
624zz Ball Bearing
No.35
2
M3 x50mm screw
No.28
3
M4 x 25mm screw
No.31
2
M4 locking nut
No.16
2
wing nut
No.42
1
L430mm smooth rod
No.2
2
locking ring
No.35
2
X axis Fender
No.A27
2
Add the belt
Timing belt
No.39
1
M3 x8mm screw
No.21
1
M3 washer
No.7
1
500px
  • Tips:
19. Assemble the X axis on the printer
L322mm smooth rod
No.1
2
300mm threaded rod
No.4
2
Coupling
No.38
2
Z top mount
No.A8
2
M3 x 16mm screw
No.23
6
M3 Square nut
No.16
6
locking ring
No.32
2
Building platform
No.44
1
Heatbed set
No.53,54,55
1
wing nut
No.42
4
Hex Counter-sunk-head screw
No.19
4
Spring
No.33
4
23.Mount the LCD panel
LCD 2004
No.64
1
Knob
No.65
1
Spacer
No.50
4
M3 x 12mm screw
No.22
4
Do not mix them up.
Here you can watch the video.
Power supply Unit
No.58
1
3D Power Cable
No.60
1
M3 x 12mm screw
No.22
4
No.18
2
M3 hex nut
No. 2
2
25.Mount the control board.
Control board kit
No.62
1
Sticker
No.47
1
Heat sink
No.48
1
Spacer
No.50
4
M3 x 12mm screw
No.22
4
Here is the video.
26.Wiring
File:15 y motor1.jpg
File:15 z motor1.jpg
4) Connect Extruder motors
Connect extruder 1.
Step4. Connect heating wires.
Step7. Connect wires for Fan.
EXP1 to SD card
EXP2 to LCD
Brown------L
Blue ------N
Yellow------GND
Red ------ -- + V
Black------COM
27.Mount the filament spool
M3 x 16mm screw
No.23
6
M3 Square nut
No.16
6
M3 washer
No.7
6
Spool base plate
1
Spool side pane
2
PVC tube
1
PVC tube
2
  • Each machine may have its own calibration procedure and this manual will not attempt to cover all the variations. Instead here is a list of key points that should be addressed.
  • Belts are taut.
  • Firmware settings are correct including: axis movement speeds and acceleration; temperature control; end-stops; motor directions.
  • Extruder is calibrated in the firmware with the correct steps per mm of filament.
