Building Instructions of Geeetech Prusa I3 M201
Preparation
- Download the Building instruction here.
Watch the Video here.
- Tips:
You can watch the video here.
Screw up the locking ring
watch video here
Mount the Y motor
Step 3. Push the Y Motor holder tab into the square hole in Rear -Outside Plate and Rear - Inside Plate. You may need to use a little force, but be careful not to break or crack any of the Acrylic pieces. Secure the Y Motor holder with 2 M3x20 mm Screws , 2 M3 Washers and 2 M3 Square Nuts.
Y belt driving wheel
Build the print platform
Mount the Y belt
- Tips:
Watch the video here.
Right Z motor mount
Left Z motor mount
Side panel assembly
Main frame assembly
Fan mount
Mount the Z endstop
Mount the Z motors
Mount the couplings
watch video here.
Mount the building platform.
watch video here.
1.Thread a M3 washer> spring> M3 washer in order to the M3x 50mm screw.
mount the X motor
Mount the endstop
Please notice the front and back of the plate.
Step2.fix the belt mount on the back of the carriage with 2 M3x 12mm screws and M3 hex nuts.
Assemble the the X&Z axis
Step2. Plug the threaded rod on the X motor end to the left coupling on the left bottom of the Z axis. Then thread the 340mm smooth rod into the linear bearing.
Step3. Thread the 470mm smooth rod into the X motor end > thread 2 locking rings (No.38) on the 2 rods separately > thread the extruder carriage on the two rods.
Step 4. Add another two locking rings on the smooth rod and thread the two X axis smooth rods into the hole of X idler end.
Plug the vertical threaded rod into the coupling on the right bottom of the Z axis. Then thread the 340mm smooth rod into the linear bearing. Screw up the 4 locking rings.
Assemble the Z axis top mount
X belt driving wheel
Watch video here.
Add the belt
watch video here.
Mount the hotend
watch video here.
Mount the extruders
Mount the LCD panel
EXP 1 is for the LCD.
EXP 2 is the SD card reader.
Do not mix them up.
Here you can watch the video.
Mount the control board
Here is the video.
Step1. take off the wires connected to the socket, before you do, please take a photo of the wire connection, in case you connect them wrongly later.
Step2. Thread the wires that is connected to the red switch through another hole on the bottom of the right side panel( A2) from outside to inside and connect the 3 wires (brown, blue, yellow) to the socket, do not mix them up. Refer to the above picture. Then pull the other wires out.
Step3. Mount the socket on the bottom of the right side panel( A2) with 2 M3 x 16 Hex Counter- sunk-head screws and M3 hex nut.
Step4. Thread the power cable from inside to outside.
Step4. Mount the PSU on the right side panel with 3 M4 x 12mm screws . And M4 washer.
Step5. Connect the wires to the PSU.
As you can see, there are 7 wires and 9 screws in total.
- Note the correspondence between the color of wires and the connector.
Color of wire | connectorD |
watch video here.
Mount the Y endstop
Mount the endstop on the A12 with M2.5 x 16mm screw and M2.5 hex nut
Wiring
Step1. Connect wires for motors
4) Connect Extruder motors
Connect extruder 0.
Step2. Connect heating wires
Step3. Connect wires for thermistor
Step4. Connect wires for endstop
Step5. Connect wires for Fan
Red: +
Black: -
1)Connect fan for control board at FAN3.
2)Connect fan for extruder 0 at FAN0.
4)Connect fan for hotend at FAN4.
Step6. Connect wires for LCD panel
EXP1 to LCD
EXP2 to SD card
Step7. Connect wires for power input
Step8. Connect the wires to the PSU
Brown------L
Blue ------N
Yellow------GND
Red ------ --+ V
Black------COM
Mount the filament spool
- Belts are taut.
more
For more detailed information about prusa I3 M201, please visit here
