Building Instructions of Geeetech Prusa I3 M201
Preparation
=Assemble the threaded rods of Y axis=
450mm threaded rod
No.5
2
M10 washer
No.9
8
M10 hex nut
No.13
8
M10 spring washer
No.10
6
Connecting fender
No.A14
2
Watch the Video here.
M10 washer
No.9
4
M10 hex nut
No.13
4
Y axis front support
No.A9
1
No.A10
1
Y axis rear support
No.A11
1
Y axis rear support
No.A12
1
  • Tips:
You can watch the video here.
SCS8UU Linear Bearing
No.40
4
420mm Smooth rod
No.3
2
locking ring
No.37
2
Screw up the locking ring
Mount the Y motor
stepper motor
No.66
1
Y motor holder
No.A13
1
M3 x12mm screw
No.25
3
M3 x 16mm screw
No.26
2
M3 washer
No.7
5
M3 square nut
No.17
2
Pulley
No.46
1
Y belt driving wheel
Driven wheel holder
No.43
1
Driven wheel
No.44
1
R84zz Ball Bearing
No.45
2
M3 x20mm screw
No.35
1
M4 x 25mm screw
No.17
1
M3 washer
No.7
1
M4 washer
No.8
1
M4 lock nut
No.14
1
wing nut
No.15
1
Build the print platform
Building platform support
No.A15
1
Belt mount
No.39
1
M3 x12mm screw
No.25
2
M4 x 16mm screw
No.34
16
M3 washer
No.7
2
M4 washer
No.8
16
