Building Instructions of Geeetech Prusa I3 M201
Preparation
=Assemble the threaded rods of Y axis=
Watch the Video here.
File:2front and back support.jpg
- Tips:
You can watch the video here.
Screw up the locking ring
Mount the Y motor
