Geeetech G2 & G2s pro Building instruction
Preparation
9. There are step-by-step videos for you to refer, please combine this instruction with the video to help you finish the work. For instruction videos, please subscribe our YouTube Channel.
Base Assembly
Motor holder assembly
Step1. Assemble A3 and 2 A4 together, and screw up with M3 x 16 screws, M3 square nut and M3 washer.
Repeat the steps for the other 2 motor holders.
Step1. Mount the motor end to the 3 tower of the base plate (A2 ). Fix them with 9 M3 x 16 Screws, Square nuts and M3 washers.
Step2. Mount the pulley on the motor shaft, one of the screws should be screwed on the cross section, the flat side of the shaft. Screw it tightly.
Step3. Mount the 3 assembled motor to the motor holder; screw it up with M3x12 screws and M3 washers.
- Note the direction of the wire connector, it is better to be on the either left or right side.
Mount the LCD panel
Step1. Assemble the LCD frame and support plate together, screw up with M3 x 16 Screws and M3 square nuts.
Step3. Screw up the frame and LCD2004 with 4 M3 x 12 Screws and washers.
Step5. Mount the assembled LCD kit onto the base plate. Screw it up with 2 M3 x 16 screws, M3 square nuts and washers.
Mount the fan
Step1. Mount the fan on the fan mount; screw it up with 2 M3 x 25 screw and M3 nut and washer.
Step2. Mount the assembled fan mount on A2 with a M3 x 16 screw and M3 square nut and washer.
Mount the control board.
Step1. Plug the aircraft- type spacer into the 4 screw hole on the control board from back to front
Step2. Screw the control board to the base plate (A2) with 4 M3 x 12 Screws and m3 washer.
Note the fan is better to be towards the MOSFET of the board.
Mount the print bed.
- for your convenience, the heatbed for you is pre-soldered, you can mount them directly.
Step2. Thread the M3x30mm Hex Counter-sunk-head screw through the two plates and add washers and spring at this end.
Here is the finished picture.
Top Plate Assembly
Drive wheel mount
Step1. Mount the Drive wheel mount on A1; screw them up with M3 x 25 screws, M3 nut and washers.
Repeat for the other two.
Endstop mount
Step1. Mount the three end stops onto the Endstop mount (A6) in the same direction, screw with M2.5 x 16 screws and M2.5 nut tightly
Step2. Bent the wire connector a bit.
You should do it very gently and note the direction, or it will break easily.
Step2. Mount the assembled parts onto the top plate. Screw up with M3 x 16 screws, M3 square nuts and M3 washers. Again,note the directions of the endstop.
- The opening of the endstop should be in clockwise direction or anti-clockwise direction.
Assemble the carriage
Step1. Fix the belt mount on the A12 with 2 M3 x12 screws and washer.
Step2. Fix the Endstop trigger mount on the other side of the A12 with 2 M3 x 12mm screws and washer.
Step3. Connect the diagonal rod joint and the SCS10UU linear bearing with the A12 in between. Fix it up with 8 M5x16mm screws.
Note the direction of the diagonal rod joint, the wider edge is near the Endstop trigger mount.
Step3. Put the M3x40mm screw into the Endstop trigger mount with a spring in between. Here you need to use washers
Repeat the steps for the rest two carriages.
The 3 carriages should be exactly the same.
Step4. Insert the rod-end bearing holder into the diagonal rod joint, fix it with a M3x8mm screw and M3 washer.
Repeat the step for the other 2 carriages.
Assemble the print platform
mount the fan
Step1. Screw the fan onto the slant side of the fan mount with 2 M3x 20 screws and M3 washers.
Step2. Mount the assembled fan mount on the spider with 2 M3 x16mm screws.
Mount the Probe mount
Mount the Probe mount on the spider with 2 M2.5 x16mm screws from bottom to up.
Mount the rod-end bearing holder and diagonal rod
Step1.Insert the rod-end bearing holder into the diagonal rod joint on the spider, fix it with M3x8mm screw and M3 washer.
Step2. Fix the Diagonal Rod on the rod-end bearing holder with Round head screw with pad.
Mount the endstop and the probe.
Step1. Mount the endstop on the spider close to the probe mount with 2 M2.5 x 8 screws.
Step2. Put the probe into the probe mount and lock it with a lock ring and spring.
