Arduino GPRS Shield
Revision as of 01:31, 12 March 2012 by Admin (talk | contribs)
  • GPRS multi-slot class 10/8
  • GPRS mobile station class B
  • Compliant to GSM phase 2/2+
  • RTC supported.
  • Selectable serial port.
  • Speaker and Headphone jacks
Application Ideas
Cautions
  • NewSoftLibrary library only support baudrate under 38400bps, it may lose data while communicate over 38400bps.
  • The standard NewSoftSerial library doesn't have support for receive on the Mega. Bhagman has written a new version of NewSoftSerial that has this support:
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1287382108
http://code.google.com/p/rogue-code/downloads/detail?name=NewSoftSerial10c-withMegaAndStream.zip
He've tried this new library. One limitation is that it only works on pins that support interrupts(Pin11,12), so on the Mega it only works on Hardware UART.
  • The default Buffer of Rx in NewSoftSerial.h is 32, you may experience some data lose while the returns of SIM900 are many(Receiving SMS/TCPIP), you can try to change the Buffer of Rx in NewSoftSerial.h into
Hardware Diagram
Getting Started
Examples
Schematics
Resources
