Rambo
Rambo(RepRap Arduino-compatible Mother Board)is a microcontroller board of 3D printer which integrates the stepper motor, hotbed, extruder, fan driver and thermometry in one. Rambo is completely compatible with Arduino in that it adapts the same IC, ATMEGA 2560, with Arduino mega2560. 3 additional resettable fuses are added to Rambo to protect it from over current. What’s more, the motor drive current can be controlled with code. The present popular LCDs that Rambo supports are smart controller 2004 and 12864.
1. Adopting the IC atmega2560 and atmega16u2 that are completely compatible with Arduino
2. 4 interface for thermometry.
3. All interfaces of 2560 and 16u2 are broken out for external use
4. 2 channel of sdramps that is compatible with SPI
5. 5 a4982 of 1/16 step size, 1 for X/Y axis respectively, 2 for Z axis, 2 for extruder.
6. Every control signal of stepper motor has a test point
7. The step size of stepper driver can be divided by firmware.
8. Reserved interface for LCD
9. 5 channel of PWM for extruder control
10. 3 power inputs source that is protected by resettable fuses: 12v 15a for hotbed; 12v 5a for extruder; 12v 5a for stepper motor.
11. PCB is composed of 4 layer of 35um copper sheet
weight:80g
Software Resources
Pc software:
Interface specifications
4 ADC interfaces (one for hotbed, 2 for extruder and one for thermometry)
5 PWM: 2 for extruder, 2 for fan control and 1 for heatbed
6 interfaces for end stop(X/Y/Z min, X/Y/Z max)which can be connected with mechanical or optical end stop, or hall sensor.
Pins
Pin Number Pin Name Arduino Pin Name RAMBO Function
1 PG5 ( OC0B ) Digital pin 4 (PWM) PWM-Ext 6
2 PE0 ( RXD0/PCINT8 ) Digital pin 0 (PWM) (RX0) USB – serial comms, SER0 3
3 PE1 ( TXD0 ) Digital pin 1 (PWM) (TX0) USB – serial comms, SER0 4
4 PE2 ( XCK0/AIN0 ) Ext2 20
5 PE3 ( OC3A/AIN1 ) Digital pin 5 (PWM) PWM-Ext 5
6 PE4 ( OC3B/INT4 ) Digital pin 2 (PWM) PWM-Ext 4
7 PE5 ( OC3C/INT5 ) Digital pin 3 (PWM) Bed Heater
8 PE6 ( T3/INT6 ) Ext2 18
9 PE7 ( CLKO/ICP3/INT7 ) Ext2 16
10 VCC VCC VCC
11 GND GND GND
12 PH0 ( RXD2 ) Digital pin 17 (PWM) (RX2) Serial 7
13 PH1 ( TXD2 ) Digital pin 16 (PWM) (TX2) Serial 8
14 PH2 ( XCK2 ) Ext2 8
15 PH3 ( OC4A ) Digital pin 6 (PWM) Fan 1
16 PH4 ( OC4B ) Digital pin 7 (PWM) Heat 1
17 PH5 ( OC4C ) Digital pin 8 (PWM) Fan 0
18 PH6 ( OC2B ) Digital pin 9 (PWM) Heat 0
19 PB0 ( SS/PCINT0 ) Digital pin 53 (PWM)(SPI-SS) SPI-Ext SS 6
20 PB1 ( SCK/PCINT1 ) Digital pin 52 (PWM)(SCK) SPI-Ext SCK 5
21 PB2 ( MOSI/PCINT2 ) Digital pin 51 (PWM)(MOSI) SPI-Ext MOSI 4
22 PB3 ( MISO/PCINT3 ) Digital pin 50(MISO) SPI-Ext MISO 3
23 PB4 ( OC2A/PCINT4 ) Digital pin 10 (PWM) Z Min Endstop
24 PB5 ( OC1A/PCINT5 ) Digital pin 11 (PWM) Y Min Endstop
25 PB6 ( OC1B/PCINT6 ) Digital pin 12 (PWM) X Min Endstop
26 PB7 ( OC0A/OC1C/PCINT7 ) Digital pin 13 (PWM) LED, PWM-Ext 3
27 PH7 ( T4 ) Ext2 6
28 PG3 ( TOSC2 ) Ext3 7
29 PG4 ( TOSC1 ) Ext3 5
30 RESET RESET Reset
31 VCC VCC VCC
32 GND GND GND
33 XTAL2 XTAL2 XTAL2
34 XTAL1 XTAL1 XTAL1
35 PL0 ( ICP4 ) Digital pin 49 Y Direction
36 PL1 ( ICP5 ) Digital pin 48 X Direction
37 PL2 ( T5 ) Digital pin 47 Z Direction
38 PL3 ( OC5A ) Digital pin 46 (PWM) MX3-5 Direction
39 PL4 ( OC5B ) Digital pin 45 (PWM) MX2-5 Direction
40 PL5 ( OC5C ) Digital pin 44 (PWM) MX1-5 Direction
41 PL6 Digital pin 43 E0 Direction
42 PL7 Digital pin 42 E1 Direction
43 PD0 ( SCL/INT0 ) Digital pin 21 (SCL) I2C SCL
44 PD1 ( SDA/INT1 ) Digital pin 20 (SDA) I2C SDA
45 PD2 ( RXDI/INT2 ) Digital pin 19 (RX1) Serial 5
46 PD3 ( TXD1/INT3 ) Digital pin 18 (TX1) Serial 6
47 PD4 ( ICP1 ) Ext2 14
48 PD5 ( XCK1 ) Ext2 12
49 PD6 ( T1 ) Ext2 10
50 PD7 ( T0 ) Digital pin 38 Digipot SS
51 PG0 ( WR ) Digital pin 41 X Microstep2
52 PG1 ( RD ) Digital pin 40 X Microstep1
53 PC0 ( A8 ) Digital pin 37 X Step
54 PC1 ( A9 ) Digital pin 36 Y Step
55 PC2 ( A10 ) Digital pin 35 Z Step
56 PC3 ( A11 ) Digital pin 34 E0 Step
57 PC4 ( A12 ) Digital pin 33 E1 Step
58 PC5 ( A13 ) Digital pin 32 MX1-4 Step
59 PC6 ( A14 ) Digital pin 31 MX2-4 Step
60 PC7 ( A15 ) Digital pin 30 Z Max, MX3-4 Step
61 VCC VCC VCC
62 GND GND GND
63 PJ0 ( RXD3/PCINT9 ) Digital pin 15 (RX3) Serial 9
64 PJ1 ( TXD3/PCINT10 ) Digital pin 14 (TX3) Serial 10
65 PJ2 ( XCK3/PCINT11 ) Ext2 9
66 PJ3 ( PCINT12 ) Ext2 11
67 PJ4 ( PCINT13 ) Ext2 15
68 PJ5 ( PCINT14 ) Ext2 17
69 PJ6 ( PCINT 15 ) Ext2 19
70 PG2 ( ALE ) Digital pin 39 Y Microstep2
71 PA7 ( AD7 ) Digital pin 29 X Enable
72 PA6 ( AD6 ) Digital pin 28 Y Enable
73 PA5 ( AD5 ) Digital pin 27 Z Enable
74 PA4 ( AD4 ) Digital pin 26 E0 Enable
75 PA3 ( AD3 ) Digital pin 25 E1 Enable
76 PA2 ( AD2 ) Digital pin 24 X Max, MX3-3 Enable
77 PA1 ( AD1 ) Digital pin 23 Y Max, MX2-3 Enable
78 PA0 ( AD0 ) Digital pin 22 MX1-3 Enable
79 PJ7 Ext2 13
80 VCC VCC VCC
81 GND GND GND
82 PK7 ( ADC15/PCINT23 ) Analog pin 15 Y Microstep1
83 PK6 ( ADC14/PCINT22 ) Analog pin 14 Z Microstep1
84 PK5 ( ADC13/PCINT21 ) Analog pin 13 Z Microstep2
85 PK4 ( ADC12/PCINT20 ) Analog pin 12 E0 Microstep2
86 PK3 ( ADC11/PCINT19 ) Analog pin 11 E0 Microstep1
87 PK2 ( ADC10/PCINT18 ) Analog pin 10 E1 Microstep2
88 PK1 ( ADC9/PCINT17 ) Analog pin 9 E1 Microstep1
89 PK0 ( ADC8/PCINT16 ) Analog pin 8 Analog-Ext 1
90 PF7 ( ADC7/PCINT15 ) Analog pin 7 Thermistor 3, Analog-Ext 2
91 PF6 ( ADC6/PCINT14 ) Analog pin 6 Analog-Ext 3
92 PF5 ( ADC5/TMS ) Analog pin 5 Analog-Ext 4
93 PF4 ( ADC4/TMK ) Analog pin 4 Analog-Ext 5
94 PF3 ( ADC3 ) Analog pin 3 Analog-Ext 6
95 PF2 ( ADC2 ) Analog pin 2 Thermistor 2
96 PF1 ( ADC1 ) Analog pin 1 Thermistor 1
97 PF0 ( ADC0 ) Analog pin 0 Thermistor 0
98 AREF Analog Reference
99 GND GND GND
100 AVCC VCC VCC
LCD panel support
There is now a fairly easy method for using a Smart Lcd with a Rambo board. See RamboLCD for instuctions.
Fuses and lockbits
Heated bed maximum voltage
Motor Current
Fuses
Select the serial port: Tools > Serial Port, the serial port for Rambo is usually the last one.
Click to check if there is any mistake. If not, click to upload.
During the process of uploading, the 3 LEDs corresponding to TX, RX and L on mega board will blink, if the blink stops, the uploading is done.
After the uploading, you can go on with the next step. If the uploading is unsuccessful, read the error report on IDE, figure out the problem, and then try again. Some frequent errors are: a wrong select of board type and serial port.
Get Started
Rambo is the CPU of a 3d printer, manipulating the whole process of printing which can’t be put in use directly without uploading firmware.
 #define BAUDRATE 250000
  1. define MOTHERBOARD 701
This parameter is set for board type. 3D Printer has many types of main board, and the setting of IOs is different, therefore, the parameter has to correspond to the type of your board, or it can’t operate normally. For other board, you can refer to the annotation on the board.
 #define TEMP_SENSOR_0 3
 #define TEMP_SENSOR_BED 3
 #define EXTRUDE_MINTEMP 170
 #define INVERT_X_DIR false
 #define INVERT_Y_DIR true
 #define X_HOME_DIR -1
 #define Y_HOME_DIR -1
 #define Z_HOME_DIR -1
 #define X_MAX_POS 205
 #define X_MIN_POS 0
 #define Y_MAX_POS 205
 #define Y_MIN_POS 0
 #define Z_MAX_POS 200
 #define Z_MIN_POS 0
FAQS
1. I can’t upload program for Rambo using a USB.
Check if the external power supply for logic part is plugged in, or if the power supply is ok.
2. How many extruders does Rambo support?
Rambo supports at most 2 extruders.
3. What should I do if the driver installation failed?
You may encounter a problem “system cannot find the specific folder” in the process of driver installation when you use starter edition windows, because the starter edition of windows system has deleted some uncommon information for driver. The resolutions are as follows,
A: open C:\windows\inf\setupapi.dev.log
The file not only includes plug and play device, information for driver installation, but also record the reason of the failure of driver installation. Open this file and move to the end of the file you will observe the following information.
"C:\Windows\System32\DriverStore\FileRepository\ "
According to this prompt, I created another folder with the same name in the path of “C:\Windows\System32\DriverStore\FileRepository\”, as follows,
C: Download and decompress the following file and add it to the created folder mdmcpq.inf_x86_neutral_********.
32bits windows:
mdmcpq.inf_x86.rar Media:(http://www.arduino.cn/forum.php?mod=attachment&aid=MTIzMHw2ZjJkZDY1OXwxNDA0NzAyMDgxfDY0MDF8MjQ4NQ==)
64bits windows
mdmcpq.inf_amd64.rar [[Media:(http://www.arduino.cn/forum.php?mod=attachment&aid=MTIzMXxkN2QxMzdiMHwxNDA0NzAyMDgxfDY0MDF8MjQ4NQ%3D%3D) ]]
Click Windows and R
Click “ok”
Click FAQ
Click advanced options
Click windows boot settings
Click reboot button
The system will reboot and go to the advanced boot options
After the restart of the system, you can install the driver and the installation method is the same with that of windows 7.
Files
RAMBo-manual:
File:RAMBo-manual.pdf
RAMBo silk:
File:RAMBo0619silk.pdf
File:Rambo-LCD.pdf
Click here to buy RAMBo V1.2a
