Crazyflie
Revision as of 01:57, 21 November 2013 by Admin (talk | contribs)
Packaging list
  • Crazyflie control board
  • 5 x CW propellers
  • 5 x CCW propellers
  • 1 LiPo batter(170mAH)
Hardware Specification
Using the Crazyflie
