Crazyflie
Revision as of 02:43, 20 November 2013 by Admin (talk | contribs) (Usage)
Packaging list
  • Crazyflie control board
  • 5 x CW propellers
  • 5 x CCW propellers
  • 1 LiPo batter
Using the Crazyflie
