Quadcopter
Revision as of 03:28, 15 November 2013 by Admin (talk | contribs) (Update firmware)
Packaging list
  • Crazyflie control board
  • 5 x CW propellers
  • 5 x CCW propellers
  • 1 LiPo batter
  • A crazyradio
3 Start to flying
  • Start up the application
  • Press Connect
