Quadcopter
Revision as of 06:18, 13 November 2013 by Admin (talk | contribs) (Usage)
1 Introduction 2 Hardware Specification 3 Features 4 Usage 5 How to buy
The Crazyflie is a tiny quadcopter often referred to as a nano-quad, built using the PCB itself as the frame. Developed solely by open source tools and designed with development in mind. E.g. we choose 0603 components (resistors & caps) over 0402 to make it easier to replace components. The voltage regulators are adjustable which makes it possible to change the digital and analog supply voltages simply by changing a couple of resistors.
Before you go ahead and assemble the Crazyflie check the Crazyflie control board and the Crazyradio electronics:
  Attach a powered micro-USB cable to the Crazyflie control board. It should power up and blink 5 times with the green LED. After that the green LED should be fully on and the red LED should blink.
