Real Time Clock RTC DS1307 Module
- Real-time clock (RTC) counts seconds,minutes, hours, date of the month, month, daof the week, and year with leap-year compensation valid up to 2100
- 56-byte, battery-backed, nonvolatile (NV) RAM for data storage
- Two-wire serial interface
- Programmable squarewave output signal
- Automatic power-fail detect and switch circuitry
- Consumes less than 500nA in battery backup mode with oscillator running
- Optional industrial temperature range:-40°C to +85°C
- Available in 8-pin DIP or SOIC Underwriters Laboratory (UL) recognized
Pin Description
VCC - Primary Power Supply
GND - Ground
DS1307 Usage
Download the DS1307 Library then uncompress DS1307 Library into "libraries" folder of Arduino and restart ;
Testcode
#include <WProgram.h> #include <Wire.h> #include <DS1307.h> written by mattt on the Arduino forum and modified by D. Sjunnesson void setup() { Serial.begin(9600); RTC.stop(); RTC.set(DS1307_SEC,1); set the seconds RTC.set(DS1307_MIN,23); set the minutes RTC.set(DS1307_HR,12); set the hours RTC.set(DS1307_DOW,4); set the day of the week RTC.set(DS1307_DATE,15); set the date RTC.set(DS1307_MTH,7); set the month RTC.set(DS1307_YR,10); set the year RTC.start(); } void loop() { Serial.print(RTC.get(DS1307_HR,true)); read the hour and also update all the values by pushing in true Serial.print(":"); Serial.print(RTC.get(DS1307_MIN,false));read minutes without update (false) Serial.print(":"); Serial.print(RTC.get(DS1307_SEC,false));read seconds Serial.print(" "); some space for a more happy life Serial.print(RTC.get(DS1307_DATE,false));read date Serial.print("/"); Serial.print(RTC.get(DS1307_MTH,false));read month Serial.print("/"); Serial.print(RTC.get(DS1307_YR,false)); //read year Serial.println(); delay(1000); }
How to buy it
Click here to buyDS1307 module
