Arduino GPRS Shield
- GPRS multi-slot class 10/8
- GPRS mobile station class B
- Compliant to GSM phase 2/2+
- RTC supported.
- Selectable serial port.
- Speaker and Headphone jacks
Application Ideas
Cautions
Hardware Diagram
- Pins usage on Arduino
- D2 - Unused
- D3 - Unused
- D4 - Unused
- D5 - Unused
- D6 - Unused
- D10 - Unused
- D11 - Unused
- D12 - Unused
- D13 - Unused
- D14(A0) - Unused
- D15(A1) - Unused
- D16(A2) - Unused
- D17(A3) - Unused
- D18(A4) - Unused
- D19(A5) - Unused
Getting Started
- Insert a unlock SIM card
- Assemble the GSM antenna
Indicator LEDs
Power Up the GPRS Shield
void powerDown() { pinMode(9, OUTPUT); digitalWrite(9,LOW); delay(1000); digitalWrite(9,HIGH); delay(2000); digitalWrite(9,LOW); delay(3000); }
UNDER-VOLTAGE WARNNING
OVER-VOLTAGE WARNNING
UNDER-VOLTAGE POWER DOWN
OVER-VOLTAGE POWER DOWN
+CMTE:1
+CMTE:-1
+CMTE:2
+CMTE:-2
- Not all Arduino boards support software serial on D7 and D8, For example Arduino Mega and Mega 2560 only support the following pins for RX: 10, 11, 12, 13, 50, 51, 52, 53, 62, 63, 64, 65, 66, 67, 68, 69. So Arduino Mega doesn't support interrupt on Pin D7 and D8. If using GPRS shield with Ardiuno Mega, please use the hardware serial or use the jumper wires wiring GPRS TX and TX to the pins support interrupt on Ardiuno Mega. And not all pins on the Leonardo support change interrupts, so only the following can be used for RX: 8, 9, 10, 11, 14 (MISO), 15 (SCK), 16 (MOSI). More information about Softserial library please visit [1]
Upload Sketch to Arduino
+CFUN: 1
+CPIN: READY
Call Ready
SoftwareSerial library Notes
A Simple Source Code Examples
/*Note: this code is a demo for how to using gprs shield to send sms message, dial a voice call and send a http request to the website, upload data to pachube.com by TCP connection, The microcontrollers Digital Pin 7 and hence allow unhindered communication with GPRS Shield using SoftSerial Library. IDE: Arduino 1.0 or later Replace the following items in the code: 1.Phone number, don't forget add the country code 2.Replace the Access Point Name 3. Replace the Pachube API Key with your personal ones assigned to your account at cosm.com */ #include <SoftwareSerial.h> #include <String.h> SoftwareSerial mySerial(7, 8); void setup() { mySerial.begin(19200); // the GPRS baud rate Serial.begin(19200); // the GPRS baud rate delay(500); } void loop() { //after start up the program, you can using terminal to connect the serial of gprs shield, //if you input 't' in the terminal, the program will execute SendTextMessage(), it will show how to send a sms message, //if input 'd' in the terminal, it will execute DialVoiceCall(), etc. if (Serial.available()) switch(Serial.read()) { case 't': SendTextMessage(); break; case 'd': DialVoiceCall(); break; case 'h': SubmitHttpRequest(); break; case 's': Send2Pachube(); break; } if (mySerial.available()) Serial.write(mySerial.read()); } ///SendTextMessage() ///this function is to send a sms message void SendTextMessage() { mySerial.print("AT+CMGF=1\r"); //Because we want to send the SMS in text mode delay(100); mySerial.println("AT + CMGS = \"+86138xxxxx615\"");//send sms message, be careful need to add a country code before the cellphone number delay(100); mySerial.println("A test message!");//the content of the message delay(100); mySerial.println((char)26);//the ASCII code of the ctrl+z is 26 delay(100); mySerial.println(); } ///DialVoiceCall ///this function is to dial a voice call void DialVoiceCall() { mySerial.println("ATD + +86138xxxxx615;");//dial the number delay(100); mySerial.println(); } ///SubmitHttpRequest() ///this function is submit a http request ///attention:the time of delay is very important, it must be set enough void SubmitHttpRequest() { mySerial.println("AT+CSQ"); delay(100); ShowSerialData();// this code is to show the data from gprs shield, in order to easily see the process of how the gprs shield submit a http request, and the following is for this purpose too. mySerial.println("AT+CGATT?"); delay(100); ShowSerialData(); mySerial.println("AT+SAPBR=3,1,\"CONTYPE\",\"GPRS\"");//setting the SAPBR, the connection type is using gprs delay(1000); ShowSerialData(); mySerial.println("AT+SAPBR=3,1,\"APN\",\"CMNET\"");//setting the APN, the second need you fill in your local apn server delay(4000); ShowSerialData(); mySerial.println("AT+SAPBR=1,1");//setting the SAPBR, for detail you can refer to the AT command mamual delay(2000); ShowSerialData(); mySerial.println("AT+HTTPINIT"); //init the HTTP request delay(2000); ShowSerialData(); mySerial.println("AT+HTTPPARA=\"URL\",\"www.google.com.hk\"");// setting the httppara, the second parameter is the website you want to access delay(1000); ShowSerialData(); mySerial.println("AT+HTTPACTION=0");//submit the request delay(10000);//the delay is very important, the delay time is base on the return from the website, if the return datas are very large, the time required longer. //while(!mySerial.available()); ShowSerialData(); mySerial.println("AT+HTTPREAD");// read the data from the website you access delay(300); ShowSerialData(); mySerial.println(""); delay(100); } ///send2Pachube()/// ///this function is to send the sensor data to the pachube, you can see the new value in the pachube after execute this function/// void Send2Pachube() { mySerial.println("AT+CGATT?"); delay(100); ShowSerialData(); mySerial.println("AT+CSTT=\"CMNET\"");//start task and setting the APN, delay(1000); ShowSerialData(); mySerial.println("AT+CIICR");//bring up wireless connection delay(300); ShowSerialData(); mySerial.println("AT+CIFSR");//get local IP adress delay(2000); ShowSerialData(); mySerial.println("AT+CIPSPRT=0"); delay(3000); ShowSerialData(); mySerial.println("AT+CIPSTART=\"tcp\",\"api.cosm.com\",\"8081\"");//start up the connection delay(2000); ShowSerialData(); mySerial.println("AT+CIPSEND");//begin send data to remote server delay(4000); ShowSerialData(); String humidity = "1031";//these 4 line code are imitate the real sensor data, because the demo did't add other sensor, so using 4 string variable to replace. String moisture = "1242";//you can replace these four variable to the real sensor data in your project String temperature = "30";// String barometer = "60.56";// mySerial.print("{\"method\": \"put\",\"resource\": \"/feeds/42742/\",\"params\"");//here is the feed you apply from pachube delay(500); ShowSerialData(); mySerial.print(": {},\"headers\": {\"X-PachubeApiKey\":");//in here, you should replace your pachubeapikey delay(500); ShowSerialData(); mySerial.print(" \"_cXwr5LE8qW4a296O-cDwOUvfddFer5pGmaRigPsiO0");//pachubeapikey delay(500); ShowSerialData(); mySerial.print("jEB9OjK-W6vej56j9ItaSlIac-hgbQjxExuveD95yc8BttXc");//pachubeapikey delay(500); ShowSerialData(); mySerial.print("Z7_seZqLVjeCOmNbEXUva45t6FL8AxOcuNSsQS\"},\"body\":"); delay(500); ShowSerialData(); mySerial.print(" {\"version\": \"1.0.0\",\"datastreams\": "); delay(500); ShowSerialData(); mySerial.println("[{\"id\": \"01\",\"current_value\": \"" + barometer + "\"},"); delay(500); ShowSerialData(); mySerial.println("{\"id\": \"02\",\"current_value\": \"" + humidity + "\"},"); delay(500); ShowSerialData(); mySerial.println("{\"id\": \"03\",\"current_value\": \"" + moisture + "\"},"); delay(500); ShowSerialData(); mySerial.println("{\"id\": \"04\",\"current_value\": \"" + temperature + "\"}]},\"token\": \"lee\"}"); delay(500); ShowSerialData(); mySerial.println((char)26);//sending delay(5000);//waitting for reply, important! the time is base on the condition of internet mySerial.println(); ShowSerialData(); mySerial.println("AT+CIPCLOSE");//close the connection delay(100); ShowSerialData(); } void ShowSerialData() { while(mySerial.available()!=0) Serial.write(mySerial.read()); }
Schematics
Resources
SIM900_hd_v1.06.pdf
