IMU Digital Combo Board-6DOF ADXL345 and ITG3205
This product is a simple breakout for the ADXL345 accelerometer and the ITG-3205 gyro. You get a full 6 degrees of freedom With this board. The sensors communicate over I2C and one INT output pin from each sensor is broken out. If you need a simple and tiny board that gives you 6 degrees of freedom, this would be a good choice.
- Tiny
- ADXL345 accelerometer
- ITG-3205 gyro
- 3.3V input
- 2C interface
ADXL345 accelerometer datasheet
Here is a guide illustrates how to connect an IMU 6DOF board to Arduino. The following is a table describe which pins on the Arduino should be connected to the IMU 6DOF board.
VCC -> 3.3V GND -> GND SDA -> A4 SCL -> A5
IMU 6 DOF Combo Board Example code
Click here to buy IMU Digital Combo Board-6DOF ADXL345 and ITG3205
