MMA7361 Triple Axis Accelerometer Breakout
This is a breakout for freescale mma7361l analog three axis accelerometer.The MMA7361L is a low power, low profile capacitive micromachined
accelerometer featuring signal conditioning, a 1-pole low pass filter,temperature compensation, self test, 0g-Detect which detects linear freefall,and g-Select which allows for the selection between 2 sensitivities. Zero-g offset and sensitivity are factory set and require no external devices. The MMA7361L includes a Sleep Mode that makes it ideal for handheld battery powered electronics.
- Low Voltage Operation: 2.2 V – 3.6 V
- High Sensitivity (800 mV/g @ 1.5g)
- Selectable Sensitivity (±1.5g, ±6g)
- Fast Turn On Time (0.5 ms Enable Response Time)
- Self Test for Freefall Detect Diagnosis
- 0g-Detect for Freefall Protection
- Signal Conditioning with Low Pass Filter
- Robust Design, High Shocks Survivability
- RoHS Compliant
- Environmentally Preferred Product
- Low Cost
- MMA7361 libraryArduino 1.0 Only
- MMA7361 Schematic
- MMA7361L Datasheet
==Example code
#include <AcceleroMMA7361.h> AcceleroMMA7361 accelero; int x; int y; int z; void setup() { Serial.begin(9600); accelero.begin(13, 12, 11, 10, A0, A1, A2); accelero.setARefVoltage(3.3); //sets the AREF voltage to 3.3V accelero.setSensitivity(LOW); //sets the sensitivity to +/-6G accelero.calibrate(); } void loop() { x = accelero.getXRaw(); y = accelero.getYRaw(); z = accelero.getZRaw(); Serial.print("\nx: "); Serial.print(x); Serial.print("\ty: "); Serial.print(y); Serial.print("\tz: "); Serial.print(z); delay(500); //(make it readable) }
Click here to buy MMA7361 Triple Axis Accelerometer Breakout
