Building Instructions of Geeetech Prusa I3 X
Preparation
- All the acrylic plates have been etched with part ID and the plate is covered with a sheet of kraft paper, you need to tear them off.
Watch the Video here.
(this picture is just for reference, the plates are not exactly the same as that for I3 X)
- Tips:
You can watch the video here.
3.Mount the Y motor
Fix the holder plate with 2 M3 x 20mm screws and M3 square nut.
- be careful in case the Acrylic break down.
4.Y belt driving wheel
Step 1. Thread the M3 x 20 screw through the top hole on the drive wheel holder.
Step 2. Pick up 2 MR84zz ball bearings. Insert 1 MR84zz ball bearings into both ends of the drive wheel .
Step 3.Place the drive wheel in to the drive wheel holder and fix it in place with an M4 x25 screw and M4 washer. Lock the other end with a M4 lock nut . You may need a wrench to tighten M4 locking nut.
- Note: Do not screw it too tightly as it may restrict the free movement of the drive wheel. It is important that you leave enough room for the wheel to turn freely.
5. Build the print platform
Step3. Thread the L420mm smooth rod through the Y rear plate> thread a locking ring on the smooth rod> thread the assembled build platform on the smooth rod> thread the smooth rod to the Y front plate. Do the same with the other rod.
6. Mount the Y belt
- Tips:
1. Before you drill your second hole, make sure to pull belt tightly to make sure to proper placement of hole for a tight belt, if it is too loose, it will hinder the move of the print platform.
2. Loosen the Y idler wing nut when tightening belt onto the Y belt mount [No. 67] in order to make securing the belt to the block easier. Be sure to tighten wing nut fully once done.
Watch the video here.
7.Left Z motor mount
Step 1. Mount the endstop(No.52) on the endstop mount (No.A28) with two M2.5 x 16mm screws and nut.
8.Right Z motor mount
Assemble the right motor holder (No.A5) and the motor holder support (No.A6 and No.A7) together, screw it up with 2 M3 x 16mm screw and M3 Square nut.
10.Side panel assembly
11.Main frame assembly
Step 1. Thread the assembled Y axis into the main frame(A1), put the main frame between the Connecting fender and the M10 nut. The Connecting fender is at the front part of the Y axis.
Step 2. Connect the side panel to the rear support plate, screw it up with M3 x 16mm screw and M3 square nut.
Step 3. Fix the connecting fender to A1 with M3 x 20mm screw and M3 hex nut.
12.Fan mount
Mount the fan on the left back side of the A1 with with M3 x 25mm screw and M3 hex nut.
Step 1. Mount the Z-axis nut.
Mount the Z nut on the A 18 from underside to up, fix with M3 x 16mm screw and M3 washer.
2.Thread the A21 to the M3 x 50 screw.
3.Thread the spring to the the M3 x 50 screw through the hole of A21.
4.Thread A22 to the M3 x 50 screw.
5.Thread another M3 hex nut to the M3 x 50 screw, compress the spring into the M3 hex hole on A21 and A22, you need to use some force.
6.Mount them on the Left bearing bottom plate (No.A18 ).
7.Fix it up with 2 M3 x 30mm screws and M3 hex nuts.
Step 3. Mount the endstop
Mount the X motor
Mount the Z motors
17. X belt driving wheel
- Please leave enough room for the belt between the ball bearing and the screw.
Add the belt
- Tips:
1.DO NOT rush to drill the second hole now, we are not sure about the length of the belt needed until we assemble the X axis on the printer.
19. Assemble the X axis on the printer
23.Mount the LCD panel
Do not mix them up.
Here you can watch the video.
25.Mount the control board.
Here is the video.
26.Wiring
4) Connect Extruder motors
Connect extruder 1.
Step4. Connect heating wires.
- There is no “+” and “-“ polarityfor heating wires
Step7. Connect wires for Fan.
If you use the 2-pin extension wire for the fan, just plug them on the + and - pin.
EXP1 to SD card
EXP2 to LCD
Brown------L
Blue ------N
Yellow------GND
Red ------ -- + V
Black------COM
27.Mount the filament spool
- Each machine may have its own calibration procedure and this manual will not attempt to cover all the variations. Instead here is a list of key points that should be addressed.
- Belts are taut.
- Firmware settings are correct including: axis movement speeds and acceleration; temperature control; end-stops; motor directions.
- Extruder is calibrated in the firmware with the correct steps per mm of filament.
The point regarding the extruder step rate is vital. Slic3r expects that the machine will accurately produce a set amount of filament when told to do so. Too much will result in blobs and other imperfections in the print. Too little will result in gaps and poor inter-layer adhesion. For how to set up the printer, please visit our Youtube
