Geeetech M1 3D printer
Revision as of 02:25, 12 November 2024 by Admin (talk | contribs)
Printer Introduction
Main specifications
Printer type: FDM
Layer thickness: 0.1-0.2 mm
Automatic leveling: Yes
Breakpoint resume: Yes
Nozzle diameter: 0.4 mm
Printing accuracy: ±0.1 mm
Ambient temperature: 10-40 ℃
Power Input:
Net Weight(kg): 3 kg
Gross Weight(kg): 4 kg
How to Clean the Nozzle
How to Replace the Hot End
How to Replace the Screen
How to Automatically Level
How to Manually Level
Black Screen
Minimum Temperature Error
Filament cannot be extruded
3、 The printer is blocked
Solution:
Print file is not displayed
(2) Click Import
(3) Click Import Configs...
4、 Click Yes for all
3.The extruder is not working
Rough edges and corners
The side edges are uneven
How to print PLA
Nozzle temperature: 190-210℃
Bed temperature: 30-60℃
Fan Cooling: 100%
Nozzle temperature: 220-230℃
Fan Cooling: 100%
How to print ABS
Nozzle temperature: 230-250℃
Bed temperature: 90-110℃
Fan Cooling: 0%
How to print PETG
Nozzle temperature: 220-250℃
Bed temperature: 70-80℃
Fan Cooling: 30%
