Geeetech M1 3D printer
Printer Introduction
Main specifications
Printer type: FDM
Layer thickness: 0.1-0.2 mm
Automatic leveling: Yes
Breakpoint resume: Yes
Nozzle diameter: 0.4 mm
Printing accuracy: ±0.1 mm
Ambient temperature: 10-40 ℃
Power Input:
Net Weight(kg): 3 kg
Gross Weight(kg): 4 kg
How to Clean the Nozzle
How to Replace the Hot End
How to Replace the Screen
How to Automatically Level
How to Manually Level
Black Screen
Minimum Temperature Error
Filament cannot be extruded
3、 The printer is blocked
The filament cannot stick to the platform
Solution: (1) Temperature setting: PLA sets the nozzle temperature to 190-210 degrees and the hot bed temperature to 50-60 degrees. The temperature of the ABS nozzle is 240 degrees, and the temperature of the hot bed is 70~100. (2) Fan setting: When using ABS filaments, the fan does not need to be turned on during the entire printing process. When using PLA filaments, the fan needs to be turned on 100%
5、 Platform surface treatment (tape, glue) Solution: Replace the Jietai Mylar sheet, apply masking tape or apply solid glue. If there is damage and it cannot be adhered, please replace the Mylar sheet. At the same time, different filaments have different adhesion to different materials. You can use white masking tape or solid glue. PVP solid glue can be evenly applied on the platform.
Print file is not displayed
First of all, it is stated that the slice file must be in .gcode format. The printer cannot recognize other formats
2、 Open the location of the Cura slicing software and copy the geeetech_M1.def.json file to the target path: \UltiMaker Cura 5.8.1sharecuraresourcesdefinitions
(2) Click Import
(3) Click Import Configs...
4、 Click Yes for all
3.The extruder is not working
Rough edges and corners
The side edges are uneven
How to print PLA
Nozzle temperature: 190-210℃
Bed temperature: 30-60℃
Fan Cooling: 100%
Nozzle temperature: 220-230℃
Fan Cooling: 100%
How to print ABS
Nozzle temperature: 230-250℃
Bed temperature: 90-110℃
Fan Cooling: 0%
How to print PETG
Nozzle temperature: 220-250℃
Bed temperature: 70-80℃
Fan Cooling: 30%
