Geeetech M1 3D printer
Printer Introduction
Main specifications
Printer type: FDM
Layer thickness: 0.1-0.2 mm
Automatic leveling: Yes
Breakpoint resume: Yes
Nozzle diameter: 0.4 mm
Printing accuracy: ±0.1 mm
Ambient temperature: 10-40 ℃
Power Input:
Net Weight(kg): 3 kg
Gross Weight(kg): 4 kg
How to Clean the Nozzle
How to Replace the Hot End
How to Replace the Screen
How to Automatically Level
How to Manually Level
Black Screen
Minimum Temperature Error
Filament cannot be extruded
3、 The printer is blocked
The filament cannot stick to the platform
1. The nozzle is too far from the platform
Adjust the Z-axis compensation value through automatic leveling or automatic leveling. The distance from the nozzle to the platform is about the thickness of an A4 paper
2. The first layer is printed too fast
The printing speed can be reduced to ensure that the first layer is well bonded to the platform. You can reduce the printing speed by adjusting the knob on the screen, or set the first layer printing speed in the slicing software, preferably in units of 10%
3. Add Birm in the slicing parameters
Adding inner and outer Brim can increase the contact area of ​​the model, ensure that the model is better attached to the hot bed, and also ensure that the model is not easy to fall off during printing
4. There is a problem with the temperature or cooling setting:
5. Platform surface treatment (tape, glue) Solution: Replace the Jietai Mylar sheet, apply masking tape or apply solid glue. If there is damage and it cannot be adhered, please replace the Mylar sheet. At the same time, different filaments have different adhesion to different materials. You can use white masking tape or solid glue. PVP solid glue can be evenly applied on the platform.
Print file is not displayed
First of all, it is stated that the slice file must be in .gcode format. The printer cannot recognize other formats
2、 Open the location of the Cura slicing software and copy the geeetech_M1.def.json file to the target path: \UltiMaker Cura 5.8.1sharecuraresourcesdefinitions
(2) Click Import
(3) Click Import Configs...
4、 Click Yes for all
3.The extruder is not working
Rough edges and corners
The side edges are uneven
How to print PLA
Nozzle temperature: 190-210℃
Bed temperature: 30-60℃
Fan Cooling: 100%
Nozzle temperature: 220-230℃
Fan Cooling: 100%
How to print ABS
Nozzle temperature: 230-250℃
Bed temperature: 90-110℃
Fan Cooling: 0%
How to print PETG
Nozzle temperature: 220-250℃
Bed temperature: 70-80℃
Fan Cooling: 30%
