GLA10
GEEETECH GLA10 3D Printer Leveling Auxiliary Tool(https://www.youtube.com/watch?v=Xxm0mE1Qrgs)
GCode generator for GLA10 GCode generator for GLA10
GLA10 Leveling Files https://www.geeetech.com/download.html?version_id=517
Tips
① Please read this manual carefully for using GLA10 correctly.
②Please scan the QR code or log in to our website to get the G-code file that GLA10 needs.
③ Please pay attention to safety when leveling the GLA10 hot bed, so as not to hurt your fingers by the moving hot end.
Leveling Preparation
2. GCode generator for GLA10
We provide the corresponding G-codes for different hotbed sizes.Please edit the relevant information in the leveling Gcode generator.
Start Leveling
Leveling test G-code
3.Please find the submenu "Auto Towers" in the Cura main menu "Extensions" ,then click "Custom Bed Level Pattern" and select "Bed Level Pattern Type"according to your preference.
install Cura
install plug-in
slice
Product Parameters
Battery parameter:CR2032,3V
Product weight:14.5g
Packing weight:52g
