3DTouch Auto Leveling Sensor
Feature
1 Simple
2 Smart
3 High-precision
5 Technologies
6 wide Selection of Bed
Voltage: 5V
Current: 15mA
Max. Current: 300mA
Cable len3Dh: 150mm
Weight: 10g
Wiring
3-pin: Brown (-, GND) Red (+5V) Orange (control signal)
2-pin: Black (-, GND) White (Z min)
Dimension
Use of 3DTouch
Mechanical
You will need a suitable mount to attach the 3DTouch sensor to your printer.
Here is a 3DTouch sensor mount for Geeetech Prusa I3 pro B, pro C and A pro.
1. Download the stl file here and print one.
2.Fix the mount on the Extruder holder with 2 M3*6mm screw.
3.Fix the 3DTouch sensor on the sensor mount with 2 M3*16mm screws and 2 M3 nuts.
Thingiverse also has mounts for many other printer types.here are some examples
Example 1
Example 2
The mount needs to be adjustable so that the distance between the bottom of the sensor (not the pin) needs to be 8.3mm above the tip of the nozzle. The sensor should also be at least 15mm away from the hot bits.
Electrical
The 3DTouch Auto Leveling sensor has 5 wires, 3 for the first servo connection and 5v and 2 for the Z min end stop, negative and signal pins.
3DTouch can be operated in the following condition.
One I/O for control (PWM or Software PWM)
One I/O for Z min (Z Probe)
GND and +5V power
let's take our geeetech GT2560 3D Printer control board as an example.
There are several ways to connect the 3DTouch Auto Leveling sensor to GT2560, here is the easiest way.
step 1. Remove the Z max connector from the board and replace it with a 3Pin Straight Pin.You need to use soldering iron here.
step 2. Use Dupont wire to extend the wires of 3DTouch. It doesn't matter if you cannot find the wires with the same color,but do not mix the wires up.
step 3. Connect the extended wire to the GT2560 control board.
Connect the 3 pin wire to the Z max pin.
Connect the 2 pin wire to the Z min pin.
Note the wire order.
For example:
- Ramps1.4
- Rumba
Changes need to be made for the configuration.h file in the Marlin source code for 3DTouch. The required changes are similar to how you would setup a mechanical servo sensor.
Testing
When the BLTouch is first powered up it does a self test – Starting with the pin up it them goes down/up 3 times and ends up the the LED on solid. Continuous flashing means that there is an obstruction or fault.
The BLTouch acts on the following gcode that can be used manually to diagnose faults etc but you don’t need to normally worry about them.
M280 P0 S10 ; pushes the pin down
M280 P0 S90 ; pulls the pin up
M280 P0 S120 ; Self test – keeps going until you do pin up/down or release alarm
M280 P0 S160 ; Release alarm
Alarm – The 3DTouch can sense when something is wrong and then goes into alarm mode which is continuous flashing. Alarm can be triggered like an obstruction that stops the pin going up and down freely, it could be dirt etc.
Printing
Providing the firmware is correctly configured, the sensor responds to the same codes as any other sensor eg inductive, capacitive or IR. The Start Code in you slicer should contain the sequence G28 followed by G29 to do the auto bed levelling.
*Don’t put another G28 after the G29 as it will just remove the G29 results.
Calibration
These instructions are written to explain how to calibrate using a computer connected through the USB port to your printer. This process also assumes that the EEPROM has been enabled in Marlin.
From the command window of Repetier Host or Simplify3D etc enter the following:
M851 ; note the number
M851 Z0 ; set the offset to zero
G28
G1 Z0
The LCD display should show Z = 0
From the display go to the Menu then Prepare/Move axis/0.1mm/Move Z
Now move the Z axis slowly down until the nozzle is the right distance from the build plate (folded piece of paper or thin card).
*Note the Z axis value on the display it should be something like -1.5
M851 Z-1.5 ; to set the offset you got in the previous step.
M500 ; Stores the values in EEPROM so that it is not reset when you power the printer off and on.
Now you are ready to print.
If you find that you need to increase or decrease the gap then do:
M851 Z-1.4 ; this would make the gap bigger or
M851 Z-1.6 ; this would make the gap smaller
M500 ; to save the value to EEPROM
*Remember the -1.4, -1.5 and -1.6 are just examples , yours will be different.
