Building Instructions of Geeetech Prusa I3 M201
Preparation
=Assemble the threaded rods of Y axis=
Watch the Video here.
- Tips:
You can watch the video here.
Screw up the locking ring
Mount the Y motor
Y belt driving wheel
Build the print platform
Mount the Y belt
- Tips:
Watch the video here.
