Building Instructions of Geeetech Prusa I3 M201
Revision as of 08:52, 28 October 2015 by Admin (talk | contribs) (Created page with "500px Safety Instructions Building the printer will require a certain amount of physical dexterity, common sense and a thorough understanding of...")
Preparation
=Assemble the threaded rods of Y axis=
450mm threaded rod
No.5
2
M10 washer
No.9
8
M10 hex nut
No.13
8
M10 spring washer
No.10
6
Connecting fender
No.A14
2
Watch the Video here.
M10 washer
No.9
4
M10 hex nut
No.13
4
Y axis front support
No.A9
1
No.A10
1
Y axis rear support
No.A11
1
Y axis rear support
No.A12
1
File:2front and back support.jpg
  • Tips:
You can watch the video here.
SCS8UU Linear Bearing
No.40
4
420mm Smooth rod
No.3
2
locking ring
No.37
2
Screw up the locking ring
Mount the Y motor
stepper motor
No.66
1
Y motor holder
No.A13
1
M3 x12mm screw
No.25
3
M3 x 16mm screw
No.26
2
M3 washer
No.7
5
M3 square nut
No.17
2
Pulley
No.46
1
