Arduino GPRS Shield
- GPRS multi-slot class 10/8
- GPRS mobile station class B
- Compliant to GSM phase 2/2+
- RTC supported.
- Selectable serial port.
- Speaker and Headphone jacks
Application Ideas
Cautions
Hardware Diagram
- Pins usage on Arduino
- D2 - Unused
- D3 - Unused
- D4 - Unused
- D5 - Unused
- D6 - Unused
- D10 - Unused
- D11 - Unused
- D12 - Unused
- D13 - Unused
- D14(A0) - Unused
- D15(A1) - Unused
- D16(A2) - Unused
- D17(A3) - Unused
- D18(A4) - Unused
- D19(A5) - Unused
Getting Started
- Insert a unlock SIM card
- Assemble the GSM antenna
Indicator LEDs
Power Up the GPRS Shield
void powerDown() { pinMode(9, OUTPUT); digitalWrite(9,LOW); delay(1000); digitalWrite(9,HIGH); delay(2000); digitalWrite(9,LOW); delay(3000); }
UNDER-VOLTAGE WARNNING
OVER-VOLTAGE WARNNING
UNDER-VOLTAGE POWER DOWN
OVER-VOLTAGE POWER DOWN
+CMTE:1
+CMTE:-1
+CMTE:2
+CMTE:-2
Upload Sketch to Arduino
+CFUN: 1
+CPIN: READY
Call Ready
SoftwareSerial library Notes
A Simple Source Code Examples
/*Note: this code is a demo for how to using gprs shield to send sms message, dial a voice call and send a http request to the website, upload data to pachube.com by TCP connection, The microcontrollers Digital Pin 7 and hence allow unhindered communication with GPRS Shield using SoftSerial Library. IDE: Arduino 1.0 or later Replace the following items in the code: 1.Phone number, don't forget add the country code 2.Replace the Access Point Name 3. Replace the Pachube API Key with your personal ones assigned to your account at cosm.com */ #include <SoftwareSerial.h> #include <String.h> SoftwareSerial mySerial(7, 8); void setup() { mySerial.begin(19200); // the GPRS baud rate Serial.begin(19200); // the GPRS baud rate delay(500); } void loop() { //after start up the program, you can using terminal to connect the serial of gprs shield, //if you input 't' in the terminal, the program will execute SendTextMessage(), it will show how to send a sms message, //if input 'd' in the terminal, it will execute DialVoiceCall(), etc. if (Serial.available()) switch(Serial.read()) { case 't': SendTextMessage(); break; case 'r': RecieveTextMessage();//This program code by directive'r'to receive, by receiving the information after the return to call the function //to verify receiving function. But it can not display the received content in SIM. DialVoiceCall(); break; case 'd': DialVoiceCall(); break; case 'h': SubmitHttpRequest(); break; case 's': Send2Pachube(); break; } if (mySerial.available()) Serial.write(mySerial.read()); } ///SendTextMessage() ///this function is to send a sms message void SendTextMessage() { mySerial.print("AT+CMGF=1\r"); //Because we want to send the SMS in text mode delay(100); mySerial.println("AT + CMGS = \"+86138xxxxx615\"");//send sms message, be careful need to add a country code before the cellphone number delay(100); mySerial.println("A test message!");//the content of the message delay(100); mySerial.println((char)26);//the ASCII code of the ctrl+z is 26 delay(100); mySerial.println(); } void RecieveTextMessage() { //mySerial.print("AT+CMGF=1\r"); //Because we want to recieve the SMS in text mode //delay(100); mySerial.print("AT+CMGR=1\r");//Because we want to recieve the SMS in text mode delay(100); mySerial.println("AT + CSCA = \"+86135*********\"");//recieve sms message, be careful need to add a country code before the cellphone number delay(100); mySerial.println("A test message!");//the content of the message delay(100); mySerial.println((char)26);//the ASCII code of the ctrl+z is 26 delay(100); mySerial.println(); //return r; } ///DialVoiceCall ///this function is to dial a voice call void DialVoiceCall() { mySerial.println("ATD + +86138xxxxx615;");//dial the number delay(100); mySerial.println(); } ///SubmitHttpRequest() ///this function is submit a http request ///attention:the time of delay is very important, it must be set enough void SubmitHttpRequest() { mySerial.println("AT+CSQ"); delay(100); ShowSerialData();// this code is to show the data from gprs shield, in order to easily see the process of how the gprs shield submit a http request, and the following is for this purpose too. mySerial.println("AT+CGATT?"); delay(100); ShowSerialData(); mySerial.println("AT+SAPBR=3,1,\"CONTYPE\",\"GPRS\"");//setting the SAPBR, the connection type is using gprs delay(1000); ShowSerialData(); mySerial.println("AT+SAPBR=3,1,\"APN\",\"CMNET\"");//setting the APN, the second need you fill in your local apn server delay(4000); ShowSerialData(); mySerial.println("AT+SAPBR=1,1");//setting the SAPBR, for detail you can refer to the AT command mamual delay(2000); ShowSerialData(); mySerial.println("AT+HTTPINIT"); //init the HTTP request delay(2000); ShowSerialData(); mySerial.println("AT+HTTPPARA=\"URL\",\"www.google.com.hk\"");// setting the httppara, the second parameter is the website you want to access delay(1000); ShowSerialData(); mySerial.println("AT+HTTPACTION=0");//submit the request delay(10000);//the delay is very important, the delay time is base on the return from the website, if the return datas are very large, the time required longer. //while(!mySerial.available()); ShowSerialData(); mySerial.println("AT+HTTPREAD");// read the data from the website you access delay(300); ShowSerialData(); mySerial.println(""); delay(100); } ///send2Pachube()/// ///this function is to send the sensor data to the pachube, you can see the new value in the pachube after execute this function/// void Send2Pachube() { mySerial.println("AT+CGATT?"); delay(100); ShowSerialData(); mySerial.println("AT+CSTT=\"CMNET\"");//start task and setting the APN, delay(1000); ShowSerialData(); mySerial.println("AT+CIICR");//bring up wireless connection delay(300); ShowSerialData(); mySerial.println("AT+CIFSR");//get local IP adress delay(2000); ShowSerialData(); mySerial.println("AT+CIPSPRT=0"); delay(3000); ShowSerialData(); mySerial.println("AT+CIPSTART=\"tcp\",\"api.cosm.com\",\"8081\"");//start up the connection delay(2000); ShowSerialData(); mySerial.println("AT+CIPSEND");//begin send data to remote server delay(4000); ShowSerialData(); String humidity = "1031";//these 4 line code are imitate the real sensor data, because the demo did't add other sensor, so using 4 string variable to replace. String moisture = "1242";//you can replace these four variable to the real sensor data in your project String temperature = "30";// String barometer = "60.56";// mySerial.print("{\"method\": \"put\",\"resource\": \"/feeds/42742/\",\"params\"");//here is the feed you apply from pachube delay(500); ShowSerialData(); mySerial.print(": {},\"headers\": {\"X-PachubeApiKey\":");//in here, you should replace your pachubeapikey delay(500); ShowSerialData(); mySerial.print(" \"_cXwr5LE8qW4a296O-cDwOUvfddFer5pGmaRigPsiO0");//pachubeapikey delay(500); ShowSerialData(); mySerial.print("jEB9OjK-W6vej56j9ItaSlIac-hgbQjxExuveD95yc8BttXc");//pachubeapikey delay(500); ShowSerialData(); mySerial.print("Z7_seZqLVjeCOmNbEXUva45t6FL8AxOcuNSsQS\"},\"body\":"); delay(500); ShowSerialData(); mySerial.print(" {\"version\": \"1.0.0\",\"datastreams\": "); delay(500); ShowSerialData(); mySerial.println("[{\"id\": \"01\",\"current_value\": \"" + barometer + "\"},"); delay(500); ShowSerialData(); mySerial.println("{\"id\": \"02\",\"current_value\": \"" + humidity + "\"},"); delay(500); ShowSerialData(); mySerial.println("{\"id\": \"03\",\"current_value\": \"" + moisture + "\"},"); delay(500); ShowSerialData(); mySerial.println("{\"id\": \"04\",\"current_value\": \"" + temperature + "\"}]},\"token\": \"lee\"}"); delay(500); ShowSerialData(); mySerial.println((char)26);//sending delay(5000);//waitting for reply, important! the time is base on the condition of internet mySerial.println(); ShowSerialData(); mySerial.println("AT+CIPCLOSE");//close the connection delay(100); ShowSerialData(); } void ShowSerialData() { while(mySerial.available()!=0) Serial.write(mySerial.read()); }
Schematics
Resources
SIM900_hd_v1.06.pdf
solutions for no registration to network
Solutions
If you are using a Router rather than a modem or Exchanger, before networking testing for the GPRS module, you should pay attention to the following tips. 1. Specify a fixed IP address for Local Host,hereinafter referred to as ’Local Host IP’. 2. Set a Port Mapping on the Router and map the port to Local Host IP. We call the set port ‘Local Host Port’. Local Host Port is within 0 and 65535. 3. Open home page (Google), input” IP” to check your Public IP.
FAQS
Q1. Why should I specify a ‘Local Host Port’ on the Router (Port Mapping)? ADSL dials through a router and the host shares network through the router. In this case, the host usually extracts Private IP such as 192.168.x.x. for such reasons, only when you specify a ‘Local Host Port’ on the Router (Port Mapping) and forward it to the corresponding Local Host, can the Internet access to the Local Host through this Port.
Q2. Why should I specify a Fixed Private IP for the Local Host? Port Mapping is a one-to-one process. If the Local Host is specified to obtain IP automatically, the IP address will probably change when the computer restarts or reconnects to the network. Therefore, it is necessary to specify a Fixed Private IP.
Tools
1. Arduino IDE 2. Net Assist 3. STC-SIP
Steps
1, Start the “Net Assist”, choose ‘TCP server’ in the dropdown menus of “protocol” (UDP Server is not recommended), change the “Local Host IP” into the Fixed IP. Input the “Local host port” set before and then click “Connect “. As shown in following the picture. File:Gprs
2, Open STC-ISP and click ‘COM Helper’ Click ‘COM Port’ and click 115200 in ‘Baud rate’ ( if the code is unreadable in RX Buffer, then re-click Baud rate) , click “Open COM” File:Gprs (2)
Input the following code in the text box of “TX Buffer” and then press “Enter”.
AT+CLPORT=”TCP”,”2022”
Click “Send Data”. If t he “RX Buffer” shows” ok”, it is successful.
OK
Input in “TX Buffer” as follows,
(NB.IP “183.37.246.171” is a Public IP from Google; “10000” is the “Local Host Port”). And then click “Send Data”. The “RX Buffer” will appear
OK CONNECT OK
File:6 3, Verify the success of communication Input
AT+CIPSEND
in “TX Buffer”, then press “Enter”. Click “Send Data” and the “RX Buffer” appears
as follows. File:7
Input
HELLO WORLD
in “TX Buffer” and click “Send Data”, check “HEX-Mode”.
Meanwhile, input
1A
to end instruction and click “Send Data”. It is successful when you see
SEND OK
Now, ‘Helloword’ will appear in “NetAssist”.
File:10 Select the corresponding IP address and click “Send”. “RX Buffer” dialog in STC-ISP will accept the information returned as below.
