Banana Pi
It’s an open-source single-board computer. It can run Android 4.4, Ubuntu, Debian, Rasberry Pi Image, as well as the Cubieboard Image. It uses the AllWinner A20 SoC, and has 1GB DDR3 SDRAM. Banana Pi is for anyone who wants to start creating with technology – not just consuming it. It's a simple, fun, useful tool that you can use to start taking control of the world around you.
Hardware specification
CPU: A20 ARM® Cortex™-A7 Dual-Core GPU: ARM Mali400MP2 Complies with OpenGL ES 2.0/1.1 Memory (SDRAM): 1GB DDR3 (shared with GPU) Onboard Storage: SD (Max. 64GB) / MMC card slot UP to 2T on SATA disk Onboard Network: 10/100/1000 Ethernet RJ45 (optional USB WIFI Dongle) Camera Input: A CSI input connector allows for the connection of a designed camera module Sound Input: Mic Video Outputs: HDMI, CVBS , LVDS/RGB Audio Output: 3.5 mm Jack and HDMI Power Source: 5 volt via MicroUSB(DC In Only) and/or MicroUSB (OTG) USB 2.0 Ports: 2 (direct from Allwinner A20 chip) Buttons: Reset button: Next to MicroUSB connector
        Power button: Next to Reset button
        UBoot button (optional): Behind HDMI connector
GPIO(2X13) pin:GPIO,UART,I2C bus,SPI bus with two chip selects,
              CAN bus,ADC,PWM,+3.3v,+5v,ground.
LED: Power Status LED (Red)
    Ethernet Status LED (Blue)
    User Define LED (Green)
Remote:IR Supported OS : Android/Android 4.4/Debian/Ubuntu/Raspberry Pi Product size : 92 mm × 60mm
