Crazyflie
Revision as of 06:53, 20 November 2013 by Admin (talk | contribs)
Packaging list
  • Crazyflie control board
  • 5 x CW propellers
  • 5 x CCW propellers
  • 1 LiPo batter
Hardware Specification
Using the Crazyflie
  • User Guide/Introduction: Short user guide that introduces some basic concepts
  • Asssembly: Instructions on how to assemble the Crazyflie kit
  • Binary distributions: Download links for the binary distribution of the PC client, Crazyradio Windows driver and the Crazyflie PC Client
  • GUI Application: Userguide for the Graphical user interface
  • Installation: Install instructions for PC side software
  • Input devices: What input devices are supported and how do you get them working
