Crazyflie
Packaging list
- Crazyflie control board
- 5 x CW propellers
- 5 x CCW propellers
- 1 LiPo batter
- Radio bootloader which enables wireless Update firmware
Using the Crazyflie
- User Guide/Introduction: Short user guide that introduces some basic concepts
- Asssembly: Instructions on how to assemble the Crazyflie kit
- Binary distributions: Download links for the binary distribution of the PC client, Crazyradio Windows driver and the Crazyflie PC Client
- GUI Application: Userguide for the Graphical user interface
- Installation: Install instructions for PC side software
- Input devices: What input devices are supported and how do you get them working
