GUI Application
Revision as of 03:32, 20 November 2013 by Admin (talk | contribs) (Created page with "* Download the client and install it [https://bitbucket.org/bitcraze/crazyflie-pc-client/downloads/cfclient-win32-install-2013.4.1.exe] * If you get error about missing dll,...")
  • Start up the application
  • Press Connect
