Quadcopter
The Crazyflie is a tiny quadcopter often referred to as a nano-quad, built using the PCB itself as the frame. Developed solely by open source tools and designed with development in mind. E.g. we choose 0603 components (resistors & caps) over 0402 to make it easier to replace components. The voltage regulators are adjustable which makes it possible to change the digital and analog supply voltages simply by changing a couple of resistors.
Packaging list
- Crazyflie control board
- 5 x CW propellers
- 5 x CCW propellers
- 1 LiPo batter
- A crazyradio
- Radio bootloader which enables wireless Update firmware
1.Assembly
2 Start to flying
- Download the client and install it [1]
- If you get error about missing dll, download and install the [2]
- Start up the application
- Insert the joystick and Crazyradio,install the Crazyradio Windows driver [3]
- Before you press connect make sure that the joystick is working as expected
- Press Connect
- Wait for the scanning to complete
- Double-click the Crazyflie you want to connect to. There's one debug URI for UI testing so you should connect to the URI that begins with radio://XX/XX/XX
- The client will now connect to the Crazyflie and handshake
- One the handshake is done you can start flying the Crazyflie. Remember the most tricky part is the thrust so start out easy
Update firmware
For updating the Crazyflie firmware there's the possibility to enter bootloader mode and flash new firmware from within the client. The bootloader mode is accessed from the menu Crazyflie→Bootloader.
To update the firmware in the Crazyflie do the following:
- Make sure that the Crazyflie is disconnected from the client and powered off
- Go to the menu Crazyflie→Bootloader
- Click “Initiate bootloader cold boot”
- Power on the Crazyflie within 5 seconds using the battery (not USB), the booloader should now connect
- Press “Browse” and select the binary you want to download (e.g. cflie.bin)
- Press “Program” and wait
- Press “Restart in firmware mode”
- To check the firmware version, under the View menu, open up Tabs→Console tab and look at the output when connecting to the Crazyflie.
