Quadcopter
The Crazyflie is a tiny quadcopter often referred to as a nano-quad, built using the PCB itself as the frame. Developed solely by open source tools and designed with development in mind. E.g. we choose 0603 components (resistors & caps) over 0402 to make it easier to replace components. The voltage regulators are adjustable which makes it possible to change the digital and analog supply voltages simply by changing a couple of resistors.
Packaging list
- Crazyflie control board
- 5 x CW propellers
- 5 x CCW propellers
- 1 LiPo batter
- A crazyradio
- Radio bootloader which enables wireless Update firmware
1.Assembly
2 Start to flying
- Download the client and install it [1]
- If you get error about missing dll, download and install the [2]
- Start up the application
- Insert the joystick and Crazyradio,install the Crazyradio Windows driver [3]
- Before you press connect make sure that the joystick is working as expected
- Press Connect
- Wait for the scanning to complete
- Double-click the Crazyflie you want to connect to. There's one debug URI for UI testing so you should connect to the URI that begins with radio://XX/XX/XX
- The client will now connect to the Crazyflie and handshake
- One the handshake is done you can start flying the Crazyflie. Remember the most tricky part is the thrust so start out easy
Update firmware
Reservd
