Geeetech M1 3D printer
Printer Introduction
Main specifications
Printer type: FDM
Layer thickness: 0.1-0.2 mm
Automatic leveling: Yes
Breakpoint resume: Yes
Nozzle diameter: 0.4 mm
Printing accuracy: ±0.1 mm
Ambient temperature: 10-40 ℃
Power Input:
Net Weight(kg): 3 kg
Gross Weight(kg): 4 kg
How to Clean the Nozzle
How to Replace the Hot End
How to Replace the Screen
How to Automatically Level
How to Manually Level
Black Screen
Minimum Temperature Error
2、 Open the Cura file and copy the geeetech_M1.def.json file to the destination path: \UltiMaker Cura 5.8.1sharecuraresourcesdefinitions
3、Copy the configuration file in the picture
4、 Copy all geeetech_M1.inst.cfg files to this path: \UltiMaker Cura 5.x.x\share\cura\resources\variants\geeetech_variants
5、 Open the Cura slicing software and follow the steps below.
10、 After the import is successful, in the printer options, select the M1 printer and confidently check whether the parameters have been imported successfully.
(2) Click Import
(3) Click Import Configs...
4、 Click Yes for all
3.The extruder is not working
Rough edges and corners
The side edges are uneven
How to print PLA
Nozzle temperature: 190-210℃
Bed temperature: 30-60℃
Fan Cooling: 100%
Nozzle temperature: 220-230℃
Fan Cooling: 100%
How to print ABS
Nozzle temperature: 230-250℃
Bed temperature: 90-110℃
Fan Cooling: 0%
How to print PETG
Nozzle temperature: 220-250℃
Bed temperature: 70-80℃
Fan Cooling: 100%
