Geeetech M1 3D printer
Printer Introduction
Main specifications
Printer type FDM
Layer thickness 0.1-0.2 mm
Printing materials PLA, ABS, TPU, PETG, Silk PLA, Wood polymer
Building platform volume 100*110*100 mm
Automatic leveling Yes
Breakpoint resume Yes
Nozzle diameter 0.4 mm
Printing accuracy ±0.1 mm
Printing speed 10~250 mm/S; 200 mm/s recommended
Operating system Windows, Mac, Linux,
Slicing software Cura, Orcaslicer
Supported file formats .gcode
Highest temperature of hot bed 60 ℃
Maximum extruder temperature 230 ℃
Ambient temperature 10-40 ℃
How to Clean the Nozzle
How to Replace the Hot End
How to Replace the Screen
How to Automatically Level
How to Manually Level
Black Screen
Minimum Temperature Error
3.The extruder is not working
Rough edges and corners
The side edges are uneven
Nozzle temperature: 220-230℃ Bed temperature: 30-60℃
How to print ABS
Nozzle temperature: 230-250℃ Bed temperature: 90-110℃
Fan speed: 0%
How to print PETG
Nozzle temperature: 220-250℃ Bed temperature: 70-80℃
