Geeetech M1 3D printer
Printer Introduction
Geeetech Mizar S is a very good 3D printer with a medium print volume on the market.
Main Specification
How to Clean the Nozzle
How to Replace the Hot End
How to Replace the Screen
How to Automatically Level
How to Manually Level
Black Screen
Minimum Temperature Error
Automatic Leveling Failed
3.The extruder is not working
The thickness of the first layer printed is uneven
Rough edges and corners
The side edges are uneven
Nozzle temperature: 220-230℃ Bed temperature: 30-60℃
How to print ABS
Nozzle temperature: 230-250℃ Bed temperature: 90-110℃
Fan speed: 0%
How to print PETG
Nozzle temperature: 220-250℃ Bed temperature: 70-80℃
