Geeetech M1 3D printer
Revision as of 09:01, 24 October 2024 by Admin (talk | contribs)
Printer Introduction
Geeetech Mizar S is a very good 3D printer with a medium print volume on the market.
Main Specification
How to Clean the Nozzle
How to Replace the Hot End
How to Replace the Screen
How to Automatically Level
How to Manually Level
3.1 Black Screen
3.2 Update Firmware
3.3 Minimum Temperature Error
3.4 Automatic Leveling Failed
3.5 How to Import Profiles into Cura
3.The extruder is not working
The thickness of the first layer printed is uneven
Rough edges and corners
The side edges are uneven
Nozzle temperature: 220-230℃ Bed temperature: 30-60℃
How to print ABS
Nozzle temperature: 230-250℃ Bed temperature: 90-110℃
Fan speed: 0%
How to print PETG
Nozzle temperature: 220-250℃ Bed temperature: 70-80℃
