GLA10
Tips
1. Please read this manual carefully for using GLA10 correctly.
2. Please scan the QR code or log in to our website to get the G-code file that GLA10 needs.
3. Please pay attention to safety when leveling the GLA10 hot bed, so as not to hurt your fingers by the moving hot end.
Leveling Preparation
2. GCode generator for GLA10
We provide the corresponding G-codes for different hotbed sizes.Please edit the relevant information in the leveling Gcode generator.Then download the GLA10 related G- code file.
Start Leveling
Leveling Verification Gcode
Please install the Cura slicing software (https://ultimaker.com/software/ultimaker-cura/#downloads), then go to the "Marketplace" plug-in market and install the "Auto towers" plug-in, then restart Cura. Go to the Cura main menu "Extensions" and find the sub- Menu "Auto Towers", select "Custom Bed Level Pattern", set the initial layer height and slice to generate a leveling test model
Product Parameters
Battery parameter:CR2032,3V
Product weight:14.5g
Packing weight:52g
