GLA10
Tips
1. Please read this manual carefully for using GLA10 correctly.
2. Please scan the QR code or log in to our website to get the G-code file that GLA10 needs.
3. Please pay attention to safety when leveling the GLA10 hot bed, so as not to hurt your fingers by the moving hot end.
Leveling Preparation
2. Please enter the URL https://www.geeetech.com/wiki/index.php/GLA10 in the browser, or scan the QR code below to visit our website. Then download the GLA10 related G- code file. We provide the corresponding G-codes for different hotbed sizes. The files with the "Level" mark are the leveling auxiliary files, and the G-code files with the "Test" mark are the test files after the adjustment is completed.
3. Please select the correct G-code file according to the size of your 3D printer heat bed, copy the G-code to the Micro SD card and insert it into the printer.
Code Modification
1. If the above hot bed size is not your hot bed size, you need to modify the code according to your hot bed. The following is a specific tutorial.https://www.geeetech.com/download.html?download_id=61
2.If you feel that the nozzle scratches the plate, you can measure the data below and then change the data in the red box to increase the value of offset.
File:Gla104.jpg 3.If you feel that the nozzle leveling time at each point is too long or too short, you can modify the data below to change the time you want. Please note that if the residence time is too short, it may cause the nozzle to move to the next point before leveling is completed. Modify the data with caution.
Start Leveling
Product Parameters
Battery parameter:CR2032,3V
Product weight:14.5g
Packing weight:52g
