Building Instructions of Geeetech Prusa I3 M201
Preparation
450mm threaded rod
No.5
2
M10 washer
No.9
8
M10 hex nut
No.13
8
M10 spring washer
No.10
6
Connecting fender
No.A14
2
Watch the Video here.
M10 washer
No.9
4
M10 hex nut
No.13
4
Y axis front support
No.A9
1
No.A10
1
Y axis rear support
No.A11
1
Y axis rear support
No.A12
1
  • Tips:
You can watch the video here.
SCS8UU Linear Bearing
No.39
4
420mm Smooth rod
No.3
2
locking ring
No.37
2
Screw up the locking ring
watch video here
Mount the Y motor
stepper motor
No.65
1
Y motor holder
No.A13
1
M3 x12mm screw
No.25
3
M3 x 20mm screw
No.27
2
M3 washer
No.7
5
M3 square nut
No.17
2
Pulley
No.45
1
Step 3. Push the Y Motor holder tab into the square hole in Rear -Outside Plate and Rear - Inside Plate. You may need to use a little force, but be careful not to break or crack any of the Acrylic pieces. Secure the Y Motor holder with 2 M3x20 mm Screws , 2 M3 Washers and 2 M3 Square Nuts.
Y belt driving wheel
Driven wheel holder
No.42
1
Driven wheel
No.43
1
R84zz Ball Bearing
No.44
2
M3 x20mm screw
No.27
1
M4 x 25mm screw
No.35
1
M3 washer
No.7
1
M4 washer
No.8
1
M4 lock nut
No.14
1
wing nut
No.15
1
Build the print platform
Building platform support
No.A15
1
Belt mount
No.38
1
M3 x12mm screw
No.25
2
M4 x 16mm screw
No.34
16
M3 washer
No.7
2
M4 washer
No.8
16
Mount the Y belt
Timing belt
No.46
1
M3 x8mm screw
No.23
2
M3 washer
No.7
2
  • Tips:
Watch the video here.
Right Z motor mount
M3 x 16mm screw
No.26
5
M3 Square nut
No.17
5
M3 washer
No.7
5
Motor holder
No.A5
1
Motor Holder support
No.A6
2
Left Z motor mount
M3 x 16mm screw
No.26
5
M3 Square nut
No.17
5
M3 washer
No.7
5
Motor holder (left)
No.A4
1
No.A6
1
No.A7
1
Main frame
No.A1
1
  • Be very careful here, if you can not insert them into the hole you can loose the screw on the motor mount and try again.
Side panel assembly
M3 x 16mm screw
No.26
6
M3 Square nut
No.17
6
M3 washer
No.7
6
Side panel(left)
No.A2
1
Side panel(right)
No.A3
1
Main frame assembly
M3 x 16mm screw
No.26
2
M3 x 20mm screw
No.27
4
M3 hex nut
No.12
4
M3 square nut
No.17
2
M3 washer
No.7
6
Fan mount
M3 x 25mm screw
No. 28
4
M3 hex nut
No. 12
4
M3 washer
No.7
6
Fan
No.51
1
Mount the Z endstop
M2.5 x 16mm screw
No. 21
2
M2.5 hex nut
No. 11
2
End stop
No.54
1
Mount the Z motors
stepper motor
No.65
2
M3 x12mm screw
No.25
8
M3 washer
No.7
6
Mount the couplings
Coupling
No.48
2
watch video here.
Mount the building platform.
Thermometry & Heating wire
No.58
1
Heatbed set
No.59
1
Building platform
No.60
1
wing nut
No.15
4
Hex Counter-sunk-head screw
No.19
4
Spring
No.36
4
watch video here.
Z-axis nut
No.16
1
X-axis motor end
No.M1
1
Linear Bearing LMH8LUU
No. 41
1
M3 x 50 screw
No.31
1
M3 x 6mm screw
No. 22
8
M3 washer
No. 7
2
Spring
No. 36
1
1.Thread a M3 washer> spring> M3 washer in order to the M3x 50mm screw.
mount the X motor
M3 x 6 mm screw
No.22
3
Stepper motor
No.65
1
Pulley
No.45
1
Mount the endstop
M2.5 x 8 mm screw
No. 20
2
End stop
No.54
1
Z-axis nut
No.16
1
X-axis idle end
No.M2
1
No. 41
1
M3 x 6mm screw
No. 22
8
X Carriage
No.M3
1
Bearing Bracket
No.M4
4
Extruder holder
No.M5
1
Linear BearingLM8LUU
No.40
2
Belt bracket
No.47
1
M3x6mm screw
No. 22
8
M3x12mm screw
No. 25
2
M4x6mm screw
No. 32
2
M3 nut
No.12
2
Please notice the front and back of the plate.
Step2.fix the belt mount on the back of the carriage with 2 M3x 12mm screws and M3 hex nuts.
Assemble the the X&Z axis
L320mm threaded rod
No.4
2
L340mm smooth rod
No.1
2
L470mm smooth rod
No.2
2
locking ring
No.37
4
  • Keep both end of X axis at the same place of the rod, you are advised to measure the distance of the both side so that they are at the same level when you put them up.
Step2. Plug the threaded rod on the X motor end to the left coupling on the left bottom of the Z axis. Then thread the 340mm smooth rod into the linear bearing.
Step3. Thread the 470mm smooth rod into the X motor end > thread 2 locking rings (No.38) on the 2 rods separately > thread the extruder carriage on the two rods.
Step 4. Add another two locking rings on the smooth rod and thread the two X axis smooth rods into the hole of X idler end.
Plug the vertical threaded rod into the coupling on the right bottom of the Z axis. Then thread the 340mm smooth rod into the linear bearing. Screw up the 4 locking rings.
  • Note: The smooth rods and the threaded rod of Z axis is vertical, and the X axis is horizontal ,which is very important, or it will hinder the move of the Z axis.
Assemble the Z axis top mount
Z top mount
No.A8
2
M3 x 16mm screw
No.23
6
M3 Square nut
No.17
6
locking ring
No.37
2
M3 washer
No.7
6
X belt driving wheel
Driven wheel holder
No.42
1
Driven wheel
No.43
1
R84zz Ball Bearing
No.44
2
M3 x40mm screw
No.30
1
M4 x 25mm screw
No.35
1
M3 washer
No.7
1
M4 washer
No.8
1
M4 lock nut
No.14
1
wing nut
No.15
1
Watch video here.
Add the belt
Timing belt
No.46
1
Belt bracket
No.47
1
watch video here.
Mount the hotend
Hotend
No.66
1
M4x6mm screw
No.32
2
M4 washer
No.8
1
watch video here.
Mount the extruders
Extruder
No.60
2
M4x12mm screw
No.33
8
M4 washer
No.8
8
Mount the LCD panel
LCD 2004
No.67
1
Knob
No.50
1
Spacer
No.49
4
M3 x 12mm screw
No.25
4
M3 washer
No.7
1
  • Pay attention to the two connectors at the back of the LCD.
EXP 1 is for the LCD.
EXP 2 is the SD card reader.
Do not mix them up.
Here you can watch the video.
Mount the control board
Control board kit
No.68
1
Sticker
No.56
1
Heat sink
No.55
1
Spacer
No.49
4
M3 x 12mm screw
No.25
4
M3 washer
No.7
1
Here is the video.
Power supply Unit
No.61
1
3D Power Cable
No.62
1
M4 x 12mm screw
No.33
3
M3 x 16 Hex Counter-sunk-head screw
No.18
2
M3 hex nut
No.12
2
M4 washer
No.8
1
Power Cable
No.63
1
Step1. take off the wires connected to the socket, before you do, please take a photo of the wire connection, in case you connect them wrongly later.
Step2. Thread the wires that is connected to the red switch through another hole on the bottom of the right side panel( A2) from outside to inside and connect the 3 wires (brown, blue, yellow) to the socket, do not mix them up. Refer to the above picture. Then pull the other wires out.
Step3. Mount the socket on the bottom of the right side panel( A2) with 2 M3 x 16 Hex Counter- sunk-head screws and M3 hex nut.
Step4. Thread the power cable from inside to outside.
Step4. Mount the PSU on the right side panel with 3 M4 x 12mm screws . And M4 washer.
Step5. Connect the wires to the PSU.
As you can see, there are 7 wires and 9 screws in total.
  • Note the correspondence between the color of wires and the connector.
Color of wire connectorD
Brown
L
Blue
N
Yellow
GND
Red
+ V
Black
COM
watch video here.
Mount the Y endstop
M2.5 x 16mm screw
No. 21
2
M2.5 hex nut
No. 11
2
End stop
No.54
1
Mount the endstop on the A12 with M2.5 x 16mm screw and M2.5 hex nut
Wiring
Step1. Connect wires for motors
4) Connect Extruder motors
Connect extruder 0.
Step2. Connect heating wires
  • There is no “+” and “-“ polarity for heating wires
Step3. Connect wires for thermistor
Step4. Connect wires for endstop
  • There is no “+” and “-“ polarity for endstop
Step5. Connect wires for Fan
Red: +
Black: -
1)Connect fan for control board at FAN3.
2)Connect fan for extruder 0 at FAN0.
4)Connect fan for hotend at FAN4.
Step6. Connect wires for LCD panel
EXP1 to LCD
EXP2 to SD card
Step7. Connect wires for power input
Step8. Connect the wires to the PSU
Brown------L
Blue ------N
Yellow------GND
Red ------ --+ V
Black------COM
Mount the filament spool
M3 x 16mm screw
No.23
6
M3 Square nut
No.17
6
M3 washer
No.7
6
Spool base plate
1
Spool side pane
2
PVC tube
1
PVC tube
2
Each machine may have its own calibration procedure and this manual will not attempt to cover all the variations. Instead here is a list of key points that should be addressed.
  • Belts are taut.
  • Bed is level in relation to the path of the extruder.
  • Filament rolls freely from the spool, without causing too much tension on the extruder.
more
For more detailed information about prusa I3 M201, please visit here
