Building Instructions of Geeetech Prusa I3 M201
Preparation
450mm threaded rod
No.5
2
M10 washer
No.9
8
M10 hex nut
No.13
8
M10 spring washer
No.10
6
Connecting fender
No.A14
2
Watch the Video here.
M10 washer
No.9
4
M10 hex nut
No.13
4
Y axis front support
No.A9
1
No.A10
1
Y axis rear support
No.A11
1
Y axis rear support
No.A12
1
  • Tips:
You can watch the video here.
SCS8UU Linear Bearing
No.39
4
420mm Smooth rod
No.3
2
locking ring
No.37
2
Screw up the locking ring
watch video here
Mount the Y motor
stepper motor
No.65
1
Y motor holder
No.A13
1
M3 x12mm screw
No.25
3
M3 x 20mm screw
No.27
2
M3 washer
No.7
5
M3 square nut
No.17
2
Pulley
No.45
1
Step 3. Push the Y Motor holder tab into the square hole in Rear -Outside Plate and Rear - Inside Plate. You may need to use a little force, but be careful not to break or crack any of the Acrylic pieces. Secure the Y Motor holder with 2 M3x20 mm Screws , 2 M3 Washers and 2 M3 Square Nuts.
Y belt driving wheel
Driven wheel holder
No.42
1
Driven wheel
No.43
1
R84zz Ball Bearing
No.44
2
M3 x20mm screw
No.27
1
M4 x 25mm screw
No.35
1
M3 washer
No.7
1
M4 washer
No.8
1
M4 lock nut
No.14
1
wing nut
No.15
1
Build the print platform
Building platform support
No.A15
1
Belt mount
No.38
1
M3 x12mm screw
No.25
2
M4 x 16mm screw
No.34
16
M3 washer
No.7
2
M4 washer
No.8
16
Mount the Y belt
Timing belt
No.46
1
M3 x8mm screw
No.23
2
M3 washer
No.7
2
  • Tips:
Watch the video here.
Right Z motor mount
M3 x 16mm screw
No.26
5
M3 Square nut
No.17
5
M3 washer
No.7
5
Motor holder
No.A5
1
Motor Holder support
No.A6
2
Left Z motor mount
M3 x 16mm screw
No.26
5
M3 Square nut
No.17
5
M3 washer
No.7
5
Motor holder (left)
No.A4
1
No.A6
1
No.A7
1
Main frame
No.A1
1
  • Be very careful here, if you can not insert them into the hole you can loose the screw on the motor mount and try again.
Side panel assembly
M3 x 16mm screw
No.26
6
M3 Square nut
No.17
6
M3 washer
No.7
6
Side panel(left)
No.A2
1
Side panel(right)
No.A3
1
Main frame assembly
M3 x 16mm screw
No.26
2
M3 x 20mm screw
No.27
4
M3 hex nut
No.12
4
M3 square nut
No.17
2
M3 washer
No.7
6
Fan mount
M3 x 25mm screw
No. 28
4
M3 hex nut
No. 12
4
M3 washer
No.7
6
Fan
No.51
1
Mount the Z endstop
M2.5 x 16mm screw
No. 21
2
M2.5 hex nut
No. 11
2
End stop
No.54
1
Mount the Z motors
stepper motor
No.65
2
M3 x12mm screw
No.25
8
M3 washer
No.7
6
Mount the couplings
Coupling
No.48
2
watch video here.
Mount the building platform.
Thermometry & Heating wire
No.58
1
Heatbed set
No.59
1
Building platform
No.60
1
wing nut
No.15
4
Hex Counter-sunk-head screw
No.19
4
Spring
No.36
4
watch video here.
Z-axis nut
No.16
1
X-axis motor end
No.M1
1
Linear Bearing LMH8LUU
No. 41
1
M3 x 50 screw
No.31
1
M3 x 6mm screw
No. 22
8
M3 washer
No. 7
2
Spring
No. 36
1
1.Thread a M3 washer> spring> M3 washer in order to the M3x 50mm screw.
mount the X motor
M3 x 6 mm screw
No.22
3
Stepper motor
No.65
1
Pulley
No.45
1
Mount the endstop
M2.5 x 8 mm screw
No. 20
2
End stop
No.54
1
Z-axis nut
No.16
1
X-axis idle end
No.M2
1
No. 41
1
M3 x 6mm screw
No. 22
8
X Carriage
No.M3
1
Bearing Bracket
No.M4
4
Extruder holder
No.M5
1
Linear BearingLM8LUU
No.40
2
Belt bracket
No.47
1
M3x6mm screw
No. 22
8
M3x12mm screw
No. 25
2
M4x6mm screw
No. 32
2
M3 nut
No.12
2
Please notice the front and back of the plate.
Step2.fix the belt mount on the back of the carriage with 2 M3x 12mm screws and M3 hex nuts.
Assemble the the X&Z axis
L300mm threaded rod
No.4
2
L322mm smooth rod
No.1
2
L455mm smooth rod
No.2
2
locking ring
No.37
4
  • Keep both end of X axis at the same place of the rod, you are advised to measure the distance of the both side so that they are at the same level when you put them up.
  • Note: The smooth rods and the threaded rod of Z axis is vertical, and the X axis is horizontal ,which is very important, or it will hinder the move of the Z axis.
Assemble the Z axis top mount
Z top mount
No.A8
2
M3 x 16mm screw
No.23
6
M3 Square nut
No.17
6
locking ring
No.37
2
M3 washer
No.7
6
X belt driving wheel
Driven wheel holder
No.42
1
Driven wheel
No.43
1
R84zz Ball Bearing
No.44
2
M3 x20mm screw
No.35
1
M4 x 25mm screw
No.17
1
M3 washer
No.7
1
M4 washer
No.8
1
M4 lock nut
No.14
1
wing nut
No.15
1
Watch video here.
Add the belt
Timing belt
No.46
1
Belt bracket
No.47
1
watch video here.
Mount the hotend
Hotend
No.66
1
M4x6mm screw
No.32
2
M4 washer
No.8
1
watch video here.
Mount the extruders
Extruder
No.60
2
M4x12mm screw
No.33
8
M4 washer
No.8
8
Mount the LCD panel
LCD 2004
No.67
1
Knob
No.50
1
Spacer
No.49
4
M3 x 12mm screw
No.25
4
M3 washer
No.7
1
  • Pay attention to the two connectors at the back of the LCD.
EXP 1 is for the LCD.
EXP 2 is the SD card reader.
Do not mix them up.
Here you can watch the video.
Mount the control board
Control board kit
No.68
1
Sticker
No.56
1
Heat sink
No.55
1
Spacer
No.49
4
M3 x 12mm screw
No.25
4
M3 washer
No.7
1
Here is the video.
Power supply Unit
No.61
1
3D Power Cable
No.62
1
M4 x 12mm screw
No.33
3
M3 x 16 Hex Counter-sunk-head screw
No.19
2
M3 hex nut
No.12
2
M4 washer
No.8
1
Power Cable
No.63
1
Color of wire connectorD
Brown
L
Blue
N
Yellow
GND
Red
+ V
Black
COM
watch video here.
Wiring
4) Connect Extruder motors
Connect extruder 0.
Step2. Connect heating wires.
  • There is no “+” and “-“ polarity for heating wires
  • There is no “+” and “-“ polarity for endstop
Step5. Connect wires for Fan.
Red: +
Black: -
EXP1 to LCD
EXP2 to SD card
Brown------L
Blue ------N
Yellow------GND
Red ------ --+ V
Black------COM
Mount the Y endstop
M2.5 x 16mm screw
No. 22
2
M2.5 hex nut
No. 11
2
End stop
No.54
1
Mount the Y axis endstop on A12with M2.5 x 16mm screw and M2.5 hex nut
Mount the filament spool
M3 x 16mm screw
No.23
6
M3 Square nut
No.16
6
M3 washer
No.7
6
Spool base plate
1
Spool side pane
2
PVC tube
1
PVC tube
2
Each machine may have its own calibration procedure and this manual will not attempt to cover all the variations. Instead here is a list of key points that should be addressed.
  • Belts are taut.
  • Bed is level in relation to the path of the extruder.
  • Filament rolls freely from the spool, without causing too much tension on the extruder.
