Building Instructions of Geeetech Prusa I3 M201
Preparation
* All the acrylic plate has been etched with part ID and the plate is covered with a sheet of kraft paper, you need to tear them off.
Watch the Video here.
- Tips:
You can watch the video here.
Screw up the locking ring
watch video here
Mount the Y motor
Y belt driving wheel
Build the print platform
Mount the Y belt
- Tips:
Watch the video here.
Left Z motor mount
Right Z motor mount
Side panel assembly
Mount the Z motors
Mount the Z endstop
Main frame assembly
Fan mount
Mount the couplings
watch video here.
mount the X motor
Step 3. Mount the endstop
Assemble the the Z axis
X belt driving wheel
Add the belt
Mount the hotend
Mount the control board
Here is the video.
Color of wire | connectorD |
Mount the LCD panel
Step 3. Screw up the knob .
EXP 1 is for the LCD.
EXP 2 is the SD card reader.
Do not mix them up.
Here you can watch the video.
Mount the building platform.
watch video here.
Wiring
4) Connect Extruder motors
Connect extruder 0.
Step4. Connect heating wires.
Step7. Connect wires for Fan.
Red: +
Black: -
Brown------L
Blue ------N
Yellow------GND
Red ------ --+ V
Black------COM
Mount the filament spool
- Belts are taut.
