Building Instructions of Geeetech Prusa I3 M201
Revision as of 06:37, 30 October 2015 by Admin (talk | contribs) (Wiring)
Preparation
450mm threaded rod
No.5
2
M10 washer
No.9
8
M10 hex nut
No.13
8
M10 spring washer
No.10
6
Connecting fender
No.A14
2
Watch the Video here.
M10 washer
No.9
4
M10 hex nut
No.13
4
Y axis front support
No.A9
1
No.A10
1
Y axis rear support
No.A11
1
Y axis rear support
No.A12
1
  • Tips:
You can watch the video here.
SCS8UU Linear Bearing
No.40
4
420mm Smooth rod
No.3
2
locking ring
No.37
2
Screw up the locking ring
Mount the Y motor
stepper motor
No.66
1
Y motor holder
No.A13
1
M3 x12mm screw
No.25
3
M3 x 16mm screw
No.26
2
M3 washer
No.7
5
M3 square nut
No.17
2
Pulley
No.46
1
Y belt driving wheel
Driven wheel holder
No.43
1
Driven wheel
No.44
1
R84zz Ball Bearing
No.45
2
M3 x20mm screw
No.35
1
M4 x 25mm screw
No.17
1
M3 washer
No.7
1
M4 washer
No.8
1
M4 lock nut
No.14
1
wing nut
No.15
1
Build the print platform
Building platform support
No.A15
1
Belt mount
No.39
1
M3 x12mm screw
No.25
2
M4 x 16mm screw
No.34
16
M3 washer
No.7
2
M4 washer
No.8
16
Mount the Y belt
Timing belt
No.47
1
M3 x8mm screw
No.23
2
M3 washer
No.7
2
  • Tips:
Watch the video here.
Left Z motor mount
M3 x 16mm screw
No.26
5
M3 Square nut
No.17
5
M3 washer
No.7
5
Motor holder (left)
No.A4
1
Motor Holder support
No.A6
1
No.A7
1
Main frame
No.A1
1
  • Note the direction of the A4,the small round hole is on the left.
*Be very careful here, if you can not insert them into the hole you can loose the screw on the motor mount and try again.
Right Z motor mount
M3 x 16mm screw
No.26
5
M3 Square nut
No.17
5
M3 washer
No.7
5
Motor holder
No.A5
1
No.A6
2
  • Note the direction of the A5,the small round hole is on the right.
Side panel assembly
M3 x 16mm screw
No.26
6
M3 Square nut
No.17
6
M3 washer
No.7
6
Side panel(left)
No.A2
1
Side panel(right)
No.A3
1
Mount the Z motors
stepper motor
No.66
2
M3 x12mm screw
No.25
8
M3 washer
No.7
6
Mount the Z endstop
M2.5 x 16mm screw
No. 22
2
M2.5 hex nut
No. 11
2
End stop
No.55
1
Main frame assembly
M3 x 16mm screw
No. 26
2
M3 x 20mm screw
No. 17
4
M3 hex nut
No.12
4
M3 square nut
No. 17
2
M3 washer
No.7
6
Fan mount
M3 x 30mm screw
No. 28
4
M3 hex nut
No. 12
4
M3 washer
No.7
6
Fan
No.52
1
Mount the fan on the BACK of the left side of the A1. Fix it with 4 M3 x 30mm screw, M3 washer and 4 M3 hex nut.
Mount the couplings
Coupling
No.49
2
  • the bottom of the coupling is better to be leveled with No. A4.
Z-axis nut
No.16
1
X-axis motor end
No.M1
1
Linear Bearing LMH8LUU
No. 42
1
M3 x 50 screw
No.31
1
M3 x 6mm screw
No. 22
8
M3 washer
No. 7
2
Spring
No. 36
1
1.Thread a M3 washer> spring> M3 washer in order to the M3x50mm screw.
mount the X motor.
M3 x 6 mm screw
No.22
3
Stepper motor
No.66
1
Pulley
No.46
1
Step 3. Mount the endstop
M2.5 x 8 mm screw
No. 20
2
End stop
No.55
1
Z-axis nut
No.16
1
X-axis idle end
No.M2
1
No. 42
1
M3 x 6mm screw
No. 22
8
X Carriage
No.M3
1
Bearing Bracket
No.M4
1
Extruder holder
No.M5
1
Linear BearingLM8LUU
No.41
2
Belt bracket
No.48
1
M3x6mm screw
No. 22
10
M4x6mm screw
No. 32
2
M3 nut
No.12
2
Assemble the the Z axis
L300mm threaded rod
No.4
2
L322mm smooth rod
No.1
2
L455mm smooth rod
No.2
2
locking ring
No.37
4
Z top mount
No.A8
2
M3 x 16mm screw
No.23
6
M3 Square nut
No.17
6
locking ring
No.37
2
M3 washer
No.7
6
X belt driving wheel
Driven wheel holder
No.43
1
Driven wheel
No.44
1
R84zz Ball Bearing
No.45
2
M3 x20mm screw
No.35
1
M4 x 25mm screw
No.17
1
M3 washer
No.7
1
M4 washer
No.8
1
M4 lock nut
No.14
1
wing nut
No.15
1
Add the belt
Timing belt
No.53
2
Belt bracket
No.48
1
  • Note the direction of the driving wheel, the side with bolt head should be towards the A1, or it will scratch the acrylic plate.
Mount the hotend
Hotend
No.67
1
M4x6mm screw
No.32
2
M4 washer
No.8
1
Mount the control board
Control board kit
No.69
1
Sticker
No.56
1
Heat sink
No.57
1
Spacer
No.50
4
M3 x 12mm screw
No.25
4
M3 washer
No.7
1
Here is the video.
Power supply Unit
No.62
1
3D Power Cable
No.63
1
M4 x 12mm screw
No.33
3
M3 x 16 Hex Counter-sunk-head screw
No.19
2
M3 hex nut
No.12
2
M4 washer
No.8
1
Power Cable
No.64
1
Color of wire connectorD
Brown
L
Blue
N
Yellow
GND
Red
+ V
Black
COM
Mount the LCD panel
LCD 2004
No.68
1
Knob
No.51
1
Spacer
No.50
4
M3 x 12mm screw
No.25
4
M3 washer
No.7
1
Step 3. Screw up the knob .
  • Pay attention to the two connectors at the back of the LCD.
EXP 1 is for the LCD.
EXP 2 is the SD card reader.
Do not mix them up.
Here you can watch the video.
Mount the building platform.
Thermometry & Heating wire
No.59
1
Heatbed set
No.60
1
Building platform
No.61
1
wing nut
No.16
4
No.20
4
Spring
No.36
4
Wiring
4) Connect Extruder motors
Connect extruder 0.
Step4. Connect heating wires.
  • There is no “+” and “-“ polarity for heating wires
  • There is no “+” and “-“ polarity for endstop
Step7. Connect wires for Fan.
Red: +
Black: -
Brown------L
Blue ------N
Yellow------GND
Red ------ --+ V
Black------COM
