Building Instructions of Geeetech Prusa I3 M201
Revision as of 02:50, 30 October 2015 by Admin (talk | contribs) (Fan mount)
Preparation
=Assemble the threaded rods of Y axis=
450mm threaded rod
No.5
2
M10 washer
No.9
8
M10 hex nut
No.13
8
M10 spring washer
No.10
6
Connecting fender
No.A14
2
Watch the Video here.
M10 washer
No.9
4
M10 hex nut
No.13
4
Y axis front support
No.A9
1
No.A10
1
Y axis rear support
No.A11
1
Y axis rear support
No.A12
1
  • Tips:
You can watch the video here.
SCS8UU Linear Bearing
No.40
4
420mm Smooth rod
No.3
2
locking ring
No.37
2
Screw up the locking ring
Mount the Y motor
stepper motor
No.66
1
Y motor holder
No.A13
1
M3 x12mm screw
No.25
3
M3 x 16mm screw
No.26
2
M3 washer
No.7
5
M3 square nut
No.17
2
Pulley
No.46
1
Y belt driving wheel
Driven wheel holder
No.43
1
Driven wheel
No.44
1
R84zz Ball Bearing
No.45
2
M3 x20mm screw
No.35
1
M4 x 25mm screw
No.17
1
M3 washer
No.7
1
M4 washer
No.8
1
M4 lock nut
No.14
1
wing nut
No.15
1
Build the print platform
Building platform support
No.A15
1
Belt mount
No.39
1
M3 x12mm screw
No.25
2
M4 x 16mm screw
No.34
16
M3 washer
No.7
2
M4 washer
No.8
16
Mount the Y belt
Timing belt
No.47
1
M3 x8mm screw
No.23
2
M3 washer
No.7
2
  • Tips:
Watch the video here.
Left Z motor mount
M3 x 16mm screw
No.26
5
M3 Square nut
No.17
5
M3 washer
No.7
5
Motor holder (left)
No.A4
1
Motor Holder support
No.A6
1
No.A7
1
Main frame
No.A1
1
  • Note the direction of the A4,the small round hole is on the left.
*Be very careful here, if you can not insert them into the hole you can loose the screw on the motor mount and try again.
Right Z motor mount
M3 x 16mm screw
No.26
5
M3 Square nut
No.17
5
M3 washer
No.7
5
Motor holder
No.A5
1
No.A6
2
  • Note the direction of the A5,the small round hole is on the right.
Side panel assembly
M3 x 16mm screw
No.26
6
M3 Square nut
No.17
6
M3 washer
No.7
6
Side panel(left)
No.A2
1
Side panel(right)
No.A3
1
Mount the Z motors
stepper motor
No.66
2
M3 x12mm screw
No.25
8
M3 washer
No.7
6
Mount the Z endstop
M2.5 x 16mm screw
No. 22
2
M2.5 hex nut
No. 11
2
End stop
No.55
1
Main frame assembly
M3 x 16mm screw
No. 26
2
M3 x 20mm screw
No. 17
4
M3 hex nut
No.12
4
M3 square nut
No. 17
2
M3 washer
No.7
6
Fan mount
M3 x 30mm screw
No. 28
4
M3 hex nut
No. 12
4
M3 washer
No.7
6
Fan
No.52
1
Mount the fan on the BACK of the left side of the A1. Fix it with 4 M3 x 30mm screw, M3 washer and 4 M3 hex nut.
Mount the couplings
Coupling
No.49
2
  • the bottom of the coupling is better to be leveled with No. A4.
