Arduino GPRS Shield
  • GPRS multi-slot class 10/8
  • GPRS mobile station class B
  • Compliant to GSM phase 2/2+
  • RTC supported.
  • Selectable serial port.
  • Speaker and Headphone jacks
Application Ideas
Cautions
  • NewSoftLibrary library only support baudrate under 38400bps, it may lose data while communicate over 38400bps.
  • The standard NewSoftSerial library doesn't have support for receive on the Mega. Bhagman has written a new version of NewSoftSerial that has this support:
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1287382108
http://code.google.com/p/rogue-code/downloads/detail?name=NewSoftSerial10c-withMegaAndStream.zip
He've tried this new library. One limitation is that it only works on pins that support interrupts(Pin11,12), so on the Mega it only works on Hardware UART.
  • The default Buffer of Rx in NewSoftSerial.h is 32, you may experience some data lose while the returns of SIM900 are many(Receiving SMS/TCPIP), you can try to change the Buffer of Rx in NewSoftSerial.h into
Hardware Diagram
Getting Started
AT Command syntax
AT Command is simple textual commands communicated with GPRS Shield over its serial interface (UART). The "AT" or "at" prefix must be set at the beginning of each Command line. To terminate a Command line enter <CR>. Commands are usually followed by a response that includes. "<CR><LF><response><CR><LF>" Throughout this document, only the responses are presented, <CR><LF> are omitted intentionally.
Note: A HEX string such as "00 49 49 49 49 FF FF FF FF" will be sent out through serial port at the baud rate of 115200 immediately after SIM900 is powered on. The string shall be ignored since it is used for synchronization with PC tool. Only enter AT Command through serial port after SIM900 is powered on and Unsolicited Result Code "RDY" is received from serial port. If auto-bauding is enabled, the Unsolicited Result Codes "RDY" and so on are not indicated when you start up the shield, and the "AT" prefix, not "at" prefix must be set at the beginning of each command line.
For more information please refer to AT Commands Manual v1.03.
Power Up the GPRS Shield
void powerUp()
 pinMode(9, OUTPUT);
 digitalWrite(9,LOW);
 delay(1000);
 digitalWrite(9,HIGH);
 delay(2000);
 delay(3000);
void powerDown()
 pinMode(9, OUTPUT);
 delay(1000);
 delay(2000);
 delay(3000);
UNDER-VOLTAGE WARNNING
OVER-VOLTAGE WARNNING
UNDER-VOLTAGE POWER DOWN
OVER-VOLTAGE POWER DOWN
+CMTE:1
+CMTE:-1
+CMTE:2
+CMTE:-2
  • When users select Software Serial to communicate, NewSoftLibrary library should be install in arduino‘s libraries.
  • NewSoftLibrary library only support baudrate under 38400bps.
Indicator LEDs
SIM Card Installation
An unlocked SIM card should be inserted in SIM Card Holder on the bottom side of the shield. Both 1.8 volts and 3.0 volts SIM Cards are supported by SIM900 and the SIM card voltage type is automatically detected by SIM900.
Note: Make sure your SIM Card is unlocked; If you not sure, you can check with your provider.
Antenna Interface
The shield comes with a GSM qurd-band antenna; Make sure the antenna is assembled and antenna pad is buckled properly.
Audio Interface
The GPRS Shield has 3.5mm Microphone interface and Speaker Interface, If you want to make voice calls, you would also require a headset with microphone.
Upload Sketch to Arduino
//at 19200 bps 8-N-1
#include <NewSoftSerial.h>
NewSoftSerial mySerial(7, 8);
   if(Serial.available())
      mySerial.print((unsigned char)Serial.read());
   else  if(mySerial.available())
      Serial.print((unsigned char)mySerial.read());
  • Make sure you install NewSoftLibrary library properly.
  • The "AT" or "at" prefix must be set at the beginning of each Command line. To terminate a Command line enter
Examples
 mySerial.begin(19200);  //Default serial port setting for the GPRS modem is 19200bps 8-N-1
 mySerial.print("\r");
 delay(1000);                    //Wait for a second while the modem sends an "OK"
 delay(1000);
 //mySerial.print("AT+CSCA=\"+919032055002\"\r");  //Setting for the SMS Message center number,
 //delay(1000);                                  //uncomment only if required and replace with
                                                 //the message center number obtained from
                                                 //your GSM service provider.
                                                 //Note that when specifying a tring of characters
                                                 // " is entered as \"
 mySerial.print("AT+CMGS=\"+9184460xxxx\"\r");    //Start accepting the text for the message
                                                 //to be sent to the number specified.
                                                 //Replace this number with the target mobile number.
 delay(1000);
 mySerial.print("Hi from Geekonfire!\r");   //The text for the message
 delay(1000);
 mySerial.print(26,BYTE);  //Equivalent to sending Ctrl+Z
     //We just want to send the SMS only once, so there is nothing in this loop.
     //If we put the code for SMS here, it will be sent again and again and cost us a lot.
Making a call: using Software UART
 delay(2000);
 mySerial.println("ATDxxxxxxxxx;"); // xxxxxxxxx is the number you want to dial.
 delay(10000);
 delay(10000);
 mySerial.println("ATH"); //End the call.
 //Do nothing
Using AT Commands to Control GPIO and PWM pins
Note: GPIOs,PWMs and ADC of the SIM900 module are all 2V8 logic
 delay(2000);
 mySerial.println("AT+SPWM=1,63,100");// set PWM 1 PIN
 mySerial.println("AT+SPWM=2,63,50");// set PWM 2 PIN
 mySerial.println("AT+SGPIO=0,1,1,1");// set GPIO 1 PIN to 1
 mySerial.println("AT+SGPIO=0,12,1,1");
 delay(1000);
 mySerial.println("AT+SGPIO=0,1,1,0");// set GPIO 1 PIN to 0
 mySerial.println("AT+SGPIO=0,12,1,0");
 delay(1000);
Schematics
GPRSshield_sch.pdf
Resources
SIM900_hd_v1.06.pdf
NewSoftLibrary
GPRS Shield can be ordered through the GOF store. Its product page is located here
