Geeetech Delta Rostock mini
Revision as of 01:30, 8 January 2015 by Admin (talk | contribs)
The Rostock mini made by Geeetech is a delta 3D printer based on the modified design of the original Rostock created by Johann. The printer is designed to have a smaller build volume allowing for a smaller, more compact, portable, and desktop friendly version of the delta RepRap design. Using OpenSCAD, the parametric nature of the design files allows for print surfaces to be configured from as small as the default 152x152 mm (6x6 inches) all the way to 300x300 mm (12x12 inches) or more. Further, construction parameters such as the length of the drive belts, diagonal rods, and a laser cuttable frame, as well as the firmware parameters such as diagonal rod length and delta radius are all automatically calculated based on the size of the specified print surface.
1. Mini- size & light weight, more compact & portable compared with other Delta RepRap design.
2. Fixed printing platform, parallel kinematic XYZ axes with low accumulated error, ensuring high precision & speed of printing.
3. Bakelite print platform with treatment of sand blast and anodization; polished oxidized high borosilicate tempered glass. Compared with aluminum sheet and acrylic sheet, the has advantages of high mechanical strength, good insulation, good heat resistance and good corrosion resistance
Main parameters
Physical Dimensions & Weight
Machine size: 280mm*340mm*700mm (L/W/H)
Packing size: 510*410*260mm (L/W/H)
Weight: 9000g
Printing Specifications
Printing Technology: Fused Filament Fabrication,FFF
Slicing software: Cura / Repetier
Control software: Repetier-Host
Data format: all 3D files converted into STL file
Layer Resolution: 0.05mm
Build Volume: 150 x 150 x 180mm
Filament Type: ABS/ PLA (ABS used only when hot bed is equipped)
Filament Diameter : 1.75mm/3mm
Nozzle Diameter: 0.3mm, 0.35mm, 0.4mm & 0.5mm optional
Location accuracy: 0.1mm
Temperature
Max Heated Bed Temp: 110 ℃
Max Extruder Temp: 240 ℃
Mechanism
Physical structure: Delta
Frame: AISI304 stainless steel optical axis with Bakelite of 6mm thickness
Build platform: tempered glass with 198mm diameter and 3mm thickness
Movement mode: printing platform fixed; X, Y and Z axes all subject to parallel movement
Extrusion system: Bowden feed
Motors: nema17, 2.5A
Electrical
Input AC 220V/2.4A(110V/4.8A),Output DC 12V/29A
Connectivity:USB or SD card
We recommend the following practice instructions for the safe and effective use of our printers. Failure to follow these practice instructions may (i) degrade your printer’s performance, (ii) cause injury and/or damage, and (iii) disqualify you from customer support. Please ensure that you have read and understand all practice instructions before using your Delta Rostock mini printer for the first time. You can contact the Delta Rostock mini Customer Support Team with any questions about the practice instructions at our [forum].
Operation
  • Never reach inside your Delta Rostock mini printer when it is turned on. Moving parts can cut or pinch you, and several parts reach high temperatures that can cause burns and other injuries.
  • Always allow your Delta Rostock mini printer to cool down for at least 5 minutes before you touch any internal part or remove a printed object.
  • Never leave your Delta Rostock mini printer unattended while printing or powered on.
  • Always turn off your Delta Rostock mini printer and disconnect it from your computer when not in use.
  • Never attempt to print using any materials that have not been approved by Delta Rostock mini.
  • Never operate your Delta Rostock mini printer if it appears damaged.
  • In case of an emergency or malfunction, immediately disconnect your Delta Rostock mini printer from the power outlet and computer.
Placement
  • Always operate your Delta Rostock mini printer in an open, well-ventilated area to allow potentially irritating fumes to dissipate.
  • Never operate your Delta Rostock mini printer outdoors, near open windows, or anywhere where it may be exposed to water or moisture.
  • Always place your Delta Rostock mini printer on a flat and sturdy surface to avoid power interruptions and deformities in your prints.
  • Never place objects on or above your Delta Rostock mini printer or power supply.
  • Always have a working fire and smoke alarm in the same room as your Delta Rostock mini printer.
  • Never place your Delta Rostock mini printer near open flames, heat sources, or flammable materials.
Connectivity
  • Plug your computer and Delta Rostock mini printer into the same power outlet for best performance.
  • We recommend plugging your Delta Rostock mini printer into a surge protector with a circuit breaker.
  • Only use the power supply that was provided with your Delta Rostock mini printer.
  • Do not plug your Delta Rostock mini printer into the same outlet as power hungry devices such as air conditioners, space heaters, or other large appliances.
Modifications
Delta Rostock mini printers are tested for performance and safety before they leave the factory. Delta Rostock mini cannot guarantee the performance or safety of printers that have been modified by users.
Warnings
  • Delta Rostock mini PRINTERS CONTAIN HEATED MOVING PARTS. NEVER REACH INSIDE THE PRINTER WHILE IT IS IN OPERATION OR BEFORE IT HAS COOLED DOWN.
  • NEVER LEAVE YOUR Delta Rostock mini PRINTER UNATTENDED WHILE POWERED ON OR PRINTING.
  • DISCONNECT YOUR Delta Rostock mini PRINTER FROM THE POWER SUPPLY AND COMPUTER WHEN NOT IN USE.
  • DO NOT ATTEMPT TO PRINT MATERIALS NOT APPROVED BY Delta Rostock mini.
  • ONLY OPERATE YOUR Delta Rostock mini PRINTER IN A WELL-VENTILATED SPACE AWAY FROM MOISTURE AND HEAT SOURCES WITH A WORKING SMOKE/FIRE ALARM.
Install the drivers
Installing Drivers Before printing, you’ll need to install drivers. The kind of driver that a Delta Rostock minirequires in order to operate properly is called a USB Serial Driver. A USB Serial Driver is software that establishes a COM port.
Windows 8
Windows Manual Install
To install all required software by Delta Rostock mini, please follow the steps provided below.
3) Open Repetier Host and Connect to your Delta Rostock mini!
How To Connect
1. Plug the USB port into your Delta Rostock mini and the other end into your computer.
Do not be alarmed if the standard messages do not appear. Because of the Delta Rostock mini’s drivers, it may show up as a generic USB device.
2. Power on the Delta Rostock mini. You can see the LED lights and fan come to life! You may be able to hear the motors idling.
6. Hit "connect" in the upper left-hand corner, select GEEEtech MeCreator. You should see the details of the connection in the console window in the bottom section of the screen.
Leveling The Print Bed
Getting the bed level in relation to the X and Y axis is very important for getting prints to stick well and is one of the first steps you should do when receiving your Delta Rostock mini. The first layer might have the right amount of squish in one area, but if another part of the bed is too low, that part of the print is more likely to come unstuck and begin to warp. The level is adjusted with the spring loaded screws, two at the front and one at the back. If you are using the standard kapton tape on the build platform and not a sheet of glass, you will need to poke holes in the tape in order to turn the leveling screws or print some thumbscrews and use a little super glue to screw them onto the bottom of the leveling screws. We suggest using the thumbscrew route so that you do not have to damage your kapton tape.
Belt Tensioning
There are 3 belts to be adjusted on your Delta Rostock mini. These steps will guide you through adjusted them.
Tools:
2.5 mm hex driver
1.5 mm hex driver
Steps
1. As always, before trying to work on any part of your Delta Rostock mini, make sure that both the bed and extruder are turned off to prevent burns. Lowering the bed will also keep it out of the way so that you can access all the necessary parts more easily.
detailes 0f me creator
