Generation 6 Electronics
Revision as of 01:36, 28 August 2014 by Admin (talk | contribs) (How to buy)
Benefits of this Design
  • These electronics are a single board solution, so you don't need all those cables and one thick sheet and 4 reprap parts less.
  • It has a standard USB connection (USB A>B cable needed)
  • It uses micro-stepping (1/8) for quieter operation.
  • It is cheaper than for example Makerbot's version of the RepRap Generation 3 electronics.
  • It uses small standard Molex connectors for motors, heater, and optos.
  • The pcb of the optos are integrated, so you only need the optos on cables with 5way Molex connectors
Hardware Features
  • on-board USB-RS232 convertor
  • Integrated hardware for driving one extruder (stepper, heater and thermistor)
  • RS485 bus connector with the possibility to link through the extruder step and dir signals
  • Integrated hardware for driving H21LOB or TCST2103 slotted optosensors
  • High input voltage range: 12-24Vdc
  • Use of standard connectors with easy and clean installation
  • Debug LEDs for power, communication and heater output
  • Reset button
  • Dimensions 110x60mm
  • Mounting grid: 100x50mm (4x M3)
  • Input voltage 12-24Vdc
  • On-board controller: ATmega 644p (Atmel Corp.)
  • RS485 connector: RJ45
  • Heat output: MOSFET output, 4A
  • Thermistors input: 100K thermistor
A modified PC Power supply will work fine. If you would prefer a power brick or 'wall wart' for the power supply 50W should be enough, but 60W is recommended.
USB
  • One (1) USB A>B cable
End-Stop Sensors
Opto-endstop
  1. - Emitter Anode(E+)
  2. - Emitter Cathode (E-)
  3. - Detector Vcc (D+)
  4. - Detector Vo (D-)
  5. - Detector Ground (Gnd)
  2. - Emitter Cathode(E-)
  3. - No Connection
  4. - Detector Vcc (D+)
  5. - Detector Vo (D-)
Mating Connector Part Numbers
  • Three (3) 5 wire Molex housing, 2.54 mm, friction ramp, polarized (2659 series, Molex part# 0022013057)
  • Fifteen (15) Molex crimp terminals (2759 series, Molex part# 0008550101)
Microswitches
  1. - No Connection
  2. - No Connection
  3. - Switch NC
  4. - Switch Common
  5. - Switch NO
  1. - No Connection
  2. - No Connection
  3. - Switch NO
  4. - Switch Common
  5. - Switch NC
Hall-Θ
The Hall-Θ board is marked (from left to right) : 5v / Gnd / Stop
For inverting firmware (or replacing a H21LOB) :
  1. No Connection
  2. No Connection
  3. +5v
  4. Stop
  5. Gnd
For non-inverting firmware (or replacing a TCST2103) :
  1. No Connection
  2. No Connection
  3. Gnd
  4. Stop
  5. +5v
Heater and Thermistor
  • One (1) 4 wire Molex housing, 2.54 mm, friction ramp, polarized (KK series, Molex part# 0022013047)
  • Four (4) Molex crimp terminals (2759 series, Molex part# 0008550101)
Pinouts listed on the PCB:
  1. NTC (Brown)
  2. NTC (Black)
  3. Heat (Yellow)
  4. Heat (Clear or gray)
Heated Bed
Stepper Motors for X, Y, Z Axes and Extruder
  • Four (4) 4 wire molex housing, 2.54 mm, friction ramp, polarized (KK series, Molex part# 0022013047)
  • Sixteen (16) Molex crimp terminals (2759 series, Molex part# 0008550101)
  • Two (2) @ 40 cm (X & E)
  • Two (2) @ 75 cm (Y & Z)
  1. A+ = A
  2. A- = B
  3. B+ = C
  4. B- = D
Adjusting the Stepper Current
File Burning
Arduino IDE 1.Windows users need install driver before uploading. The board: Tools > Board > sanguino W/ATMEGA644P 16, as shown below.
Configuring serial interface: Tools > Serial Port > the corresponding COM Port of Generation 6 is usually the last one. As shown below:
Clickto check if it is right and then click to upload firmware, as shown below
After uploading, you can go on to the next step. If you cannot upload, check the dialog box below to identify the problem and solve it. The common mistakes are the wrong select of type of board or serial
Software Setting
Arduino IDE Installation 1.Windows will prompt that a new USB device, named FT232R USB UART was found when connecting USB with generation to the PC. Then, windows will open the dialog box “found new hardware wizard”, check “no, not this time”, then click “next” to continue.
Specify “drivers” in Arduino 1.0.installation directory to install driver.
If everything goes well, windows will install the corresponding driver. After the installation complete. You can find the corresponding Generation 6device in device manager of windows.
Now, you can find the corresponding Generation 6device in device manager of windows.
Get Started
Generation 6 is the CPU of a 3D printer, manipulating the whole process of printing. Generation 6 can‘t be put in use directly without uploading firmware.
  #define BAUDRATE 250000
 #define MOTHERBOARD 5
This parameter is set for board type. 3D Printer has many types of main board, and the settings of IOs are different, therefore, the parameter has to correspond to the type of your board, or it can’t operate normally. The parameter of Generation 6should be 5 (single- nozzle). For other board, you can refer to the annotation on the board.
 #define TEMP_SENSOR_0 3
 #define TEMP_SENSOR_BED 3
 #define EXTRUDE_MINTEMP 170
 #define INVERT_X_DIR false
 #define INVERT_Y_DIR true
 #define X_HOME_DIR -1
 #define Y_HOME_DIR -1
 #define Z_HOME_DIR -1
 #define X_MAX_POS 205
 #define X_MIN_POS 0
 #define Y_MAX_POS 205
 #define Y_MIN_POS 0
 #define Z_MAX_POS 200
 #define Z_MIN_POS 0
FAQS
1. Common Configuration Modifications The configuration of the firmware is controlled by defines in configuration.h. This file has options for supporting several different boards and Mendel options. When you change a define, search for the name and make sure you are changing the right one. The top of the file sets MOTHERBOARD to 2 (which later sets MENDEL) and defines GEN6 so look for those #ifdefs to know which setting to change.
  • If you are experiencing pauses (the print head pauses for multiple seconds) you might want to try increasing the baud rate setting HOST_BAUD to 38400 or 250000.
  • If one of your axes goes in the wrong direction toggle INVERT_X_DIR (substitute Y, Z as needed) by changing it from 1 to 0 (or back). Search for GRUB_PULLEYS to get the right set of defines.
  • If the scale of one of your axes is wrong adjust X_STEPS_PER_MM (or Y or Z). There are tutorials on this you can Google. If you are using 5/16" threaded rod in an SAE Mendel you will want Z_STEPS_PER_MM set to 1133.858. Remember that the Gen6 is hardwired for 1/8 microstepping.
  • If you are getting a wildly wrong flow rate from your extruder adjust E0_STEPS_PER_MM. The comments near the define describe setting it based on how much plastic comes out of the nozzle. If you are using Skeinforge 40 you will need to instead set it based on how much filament goes in to the extruder. See "Volumetric Dimension Settings" for more details.
  • If your extruder motor runs backwards there is no INVERT_E0_DIR. You can swap the stepper pairs in your connector (as with any axis) or you can modify extruder::setDirection near line 287 of extruder.h. Note again that there are ifdefs in that file so get the right instance of that function.
2. Potential Hardware Fixes
There have been a couple of instances of dirty 5v power causing instability with the ftdi and atmega chips. If this affects you, a 1n 0805 cap soldered across R12 might help. See http://www.mendel-parts.com/new_forum/phpBB3/viewtopic.php?f=19&t=381 for details.
I wasn't having this problem, but did solder a 1nF ceramic cap across R12, and it reduced the amount of audible noise the stepper drivers made, and limited ranges of stepper actuation the noise would occur at. Meaning if I hit 0.1mm on my X and Y in pronterface, each operating point would make noise, whereas now, only some do. This mod also improved my thermistor readings, which previously would vary 20-30C, but are now pretty much dead stable.
3. The LED doesn’t light when connected to USB and 5v external power supply.
4. How to solve it if the driver installation failed?
Click here to reinstall the driver (http://www.geeetech.com/wiki/index.php/Sanguinololu) and Put it in Arduino IDE>hardware
5. What type of printer can Printrboard be applied to?
Solidoodle,printrbot,and most type of reprap(with a stepper motor driver for Z axis and single extruder)
Resources
Pc software:
Generation 6 driver: http://www.geeetech.com/wiki/index.php/Sanguinololu#FAQS
File:Gu.pdf
Were to get
here you can buy one Generation 6 Electronics
