Rambo
Rambo(RepRap Arduino-compatible Mother Board)is a microcontroller board of 3D printer which integrates the stepper motor, hotbed, extruder, fan driver and thermometry in one. Rambo is completely compatible with Arduino in that it adapts the same IC, ATMEGA 2560, with Arduino mega2560. 3 additional resettable fuses are added to Rambo to protect it from over current. What’s more, the motor drive current can be controlled with code. The present popular LCDs that Rambo supports are smart controller 2004 and 12864.
1. Adopting the IC atmega2560 and atmega16u2 that are completely compatible with Arduino
2. 4 interface for thermometry.
3. All interfaces of 2560 and 16u2 are broken out for external use
4. 2 channel of sdramps that is compatible with SPI
5. 5 a4982 of 1/16 step size, 1 for X/Y axis respectively, 2 for Z axis, 2 for extruder.
6. Every control signal of stepper motor has a test point
7. The step size of stepper driver can be divided by firmware.
8. Reserved interface for LCD
9. 5 channel of PWM for extruder control
10. 3 power inputs source that is protected by resettable fuses: 12v 15a for hotbed; 12v 5a for extruder; 12v 5a for stepper motor.
11. PCB is composed of 4 layer of 35um copper sheet
weight:80g
Software Resources
Pc software:
Interface specifications
4 ADC interfaces (one for hotbed, 2 for extruder and one for thermometry)
5 PWM: 2 for extruder, 2 for fan control and 1 for heatbed
6 interfaces for end stop(X/Y/Z min, X/Y/Z max)which can be connected with mechanical or optical end stop, or hall sensor.
Pins
Pin Number | Pin Name | Arduino Pin Name | RAMBO Function |
1 | PG5 ( OC0B ) | Digital pin 4 (PWM) | PWM-Ext 6 |
2 | PE0 ( RXD0/PCINT8 ) | Digital pin 0 (PWM) (RX0) | USB – serial comms, SER0 3 |
3 | PE1 ( TXD0 ) | Digital pin 1 (PWM) (TX0) | USB – serial comms, SER0 4 |
4 | PE2 ( XCK0/AIN0 ) | Ext2 20 | |
5 | PE3 ( OC3A/AIN1 ) | Digital pin 5 (PWM) | PWM-Ext 5 |
6 | PE4 ( OC3B/INT4 ) | Digital pin 2 (PWM) | PWM-Ext 4 |
7 | PE5 ( OC3C/INT5 ) | Digital pin 3 (PWM) | Bed Heater |
8 | PE6 ( T3/INT6 ) | Ext2 18 | |
9 | PE7 ( CLKO/ICP3/INT7 ) | Ext2 16 | |
10 | VCC | VCC | VCC |
11 | GND | GND | GND |
12 | PH0 ( RXD2 ) | Digital pin 17 (PWM) (RX2) | Serial 7 |
13 | PH1 ( TXD2 ) | Digital pin 16 (PWM) (TX2) | Serial 8 |
14 | PH2 ( XCK2 ) | Ext2 8 | |
15 | PH3 ( OC4A ) | Digital pin 6 (PWM) | Fan 1 |
16 | PH4 ( OC4B ) | Digital pin 7 (PWM) | Heat 1 |
17 | PH5 ( OC4C ) | Digital pin 8 (PWM) | Fan 0 |
18 | PH6 ( OC2B ) | Digital pin 9 (PWM) | Heat 0 |
19 | PB0 ( SS/PCINT0 ) | Digital pin 53 (PWM)(SPI-SS) | SPI-Ext SS 6 |
20 | PB1 ( SCK/PCINT1 ) | Digital pin 52 (PWM)(SCK) | SPI-Ext SCK 5 |
21 | PB2 ( MOSI/PCINT2 ) | Digital pin 51 (PWM)(MOSI) | SPI-Ext MOSI 4 |
22 | PB3 ( MISO/PCINT3 ) | Digital pin 50(MISO) | SPI-Ext MISO 3 |
23 | PB4 ( OC2A/PCINT4 ) | Digital pin 10 (PWM) | Z Min Endstop |
24 | PB5 ( OC1A/PCINT5 ) | Digital pin 11 (PWM) | Y Min Endstop |
25 | PB6 ( OC1B/PCINT6 ) | Digital pin 12 (PWM) | X Min Endstop |
26 | PB7 ( OC0A/OC1C/PCINT7 ) | Digital pin 13 (PWM) | LED, PWM-Ext 3 |
27 | PH7 ( T4 ) | Ext2 6 | |
28 | PG3 ( TOSC2 ) | Ext3 7 | |
29 | PG4 ( TOSC1 ) | Ext3 5 | |
30 | RESET | RESET | Reset |
31 | VCC | VCC | VCC |
32 | GND | GND | GND |
33 | XTAL2 | XTAL2 | XTAL2 |
34 | XTAL1 | XTAL1 | XTAL1 |
35 | PL0 ( ICP4 ) | Digital pin 49 | Y Direction |
36 | PL1 ( ICP5 ) | Digital pin 48 | X Direction |
37 | PL2 ( T5 ) | Digital pin 47 | Z Direction |
38 | PL3 ( OC5A ) | Digital pin 46 (PWM) | MX3-5 Direction |
39 | PL4 ( OC5B ) | Digital pin 45 (PWM) | MX2-5 Direction |
40 | PL5 ( OC5C ) | Digital pin 44 (PWM) | MX1-5 Direction |
41 | PL6 | Digital pin 43 | E0 Direction |
42 | PL7 | Digital pin 42 | E1 Direction |
43 | PD0 ( SCL/INT0 ) | Digital pin 21 (SCL) | I2C SCL |
44 | PD1 ( SDA/INT1 ) | Digital pin 20 (SDA) | I2C SDA |
45 | PD2 ( RXDI/INT2 ) | Digital pin 19 (RX1) | Serial 5 |
46 | PD3 ( TXD1/INT3 ) | Digital pin 18 (TX1) | Serial 6 |
47 | PD4 ( ICP1 ) | Ext2 14 | |
48 | PD5 ( XCK1 ) | Ext2 12 | |
49 | PD6 ( T1 ) | Ext2 10 | |
50 | PD7 ( T0 ) | Digital pin 38 | Digipot SS |
51 | PG0 ( WR ) | Digital pin 41 | X Microstep2 |
52 | PG1 ( RD ) | Digital pin 40 | X Microstep1 |
53 | PC0 ( A8 ) | Digital pin 37 | X Step |
54 | PC1 ( A9 ) | Digital pin 36 | Y Step |
55 | PC2 ( A10 ) | Digital pin 35 | Z Step |
56 | PC3 ( A11 ) | Digital pin 34 | E0 Step |
57 | PC4 ( A12 ) | Digital pin 33 | E1 Step |
58 | PC5 ( A13 ) | Digital pin 32 | MX1-4 Step |
59 | PC6 ( A14 ) | Digital pin 31 | MX2-4 Step |
60 | PC7 ( A15 ) | Digital pin 30 | Z Max, MX3-4 Step |
61 | VCC | VCC | VCC |
62 | GND | GND | GND |
63 | PJ0 ( RXD3/PCINT9 ) | Digital pin 15 (RX3) | Serial 9 |
64 | PJ1 ( TXD3/PCINT10 ) | Digital pin 14 (TX3) | Serial 10 |
65 | PJ2 ( XCK3/PCINT11 ) | Ext2 9 | |
66 | PJ3 ( PCINT12 ) | Ext2 11 | |
67 | PJ4 ( PCINT13 ) | Ext2 15 | |
68 | PJ5 ( PCINT14 ) | Ext2 17 | |
69 | PJ6 ( PCINT 15 ) | Ext2 19 | |
70 | PG2 ( ALE ) | Digital pin 39 | Y Microstep2 |
71 | PA7 ( AD7 ) | Digital pin 29 | X Enable |
72 | PA6 ( AD6 ) | Digital pin 28 | Y Enable |
73 | PA5 ( AD5 ) | Digital pin 27 | Z Enable |
74 | PA4 ( AD4 ) | Digital pin 26 | E0 Enable |
75 | PA3 ( AD3 ) | Digital pin 25 | E1 Enable |
76 | PA2 ( AD2 ) | Digital pin 24 | X Max, MX3-3 Enable |
77 | PA1 ( AD1 ) | Digital pin 23 | Y Max, MX2-3 Enable |
78 | PA0 ( AD0 ) | Digital pin 22 | MX1-3 Enable |
79 | PJ7 | Ext2 13 | |
80 | VCC | VCC | VCC |
81 | GND | GND | GND |
82 | PK7 ( ADC15/PCINT23 ) | Analog pin 15 | Y Microstep1 |
83 | PK6 ( ADC14/PCINT22 ) | Analog pin 14 | Z Microstep1 |
84 | PK5 ( ADC13/PCINT21 ) | Analog pin 13 | Z Microstep2 |
85 | PK4 ( ADC12/PCINT20 ) | Analog pin 12 | E0 Microstep2 |
86 | PK3 ( ADC11/PCINT19 ) | Analog pin 11 | E0 Microstep1 |
87 | PK2 ( ADC10/PCINT18 ) | Analog pin 10 | E1 Microstep2 |
88 | PK1 ( ADC9/PCINT17 ) | Analog pin 9 | E1 Microstep1 |
89 | PK0 ( ADC8/PCINT16 ) | Analog pin 8 | Analog-Ext 1 |
90 | PF7 ( ADC7/PCINT15 ) | Analog pin 7 | Thermistor 3, Analog-Ext 2 |
91 | PF6 ( ADC6/PCINT14 ) | Analog pin 6 | Analog-Ext 3 |
92 | PF5 ( ADC5/TMS ) | Analog pin 5 | Analog-Ext 4 |
93 | PF4 ( ADC4/TMK ) | Analog pin 4 | Analog-Ext 5 |
94 | PF3 ( ADC3 ) | Analog pin 3 | Analog-Ext 6 |
95 | PF2 ( ADC2 ) | Analog pin 2 | Thermistor 2 |
96 | PF1 ( ADC1 ) | Analog pin 1 | Thermistor 1 |
97 | PF0 ( ADC0 ) | Analog pin 0 | Thermistor 0 |
98 | AREF | Analog Reference | |
99 | GND | GND | GND |
100 | AVCC | VCC | VCC |
LCD panel support
There is now a fairly easy method for using a Smart Lcd with a Rambo board. See RamboLCD for instuctions.
Fuses and lockbits
USB Driver
Windows requires a driver to communicate with RAMBo. Download this file File:RAMBo USBdriver.zip and unzip it into a known location on your computer. In windows 7, plug in your RAMBo board, and let windows fail to find the driver. Then, go to the start menu, right click on computer and click properties. On the left, click on Device Manager. Scroll down to Unknown Devices, and right click on RAMBo. Choose Update driver. CLick on "Browse my computer for driver software", then click on "Let me pick from a list of device drivers on my computer", then click the button for "Have Disk" and then click browse and point it to the file you downloaded above.
Linux and Mac use the built in CDC driver. RAMBo should show as a option in your 3D printer control interface (/dev/ttyACM0 , etc.).
Maximum motor current
In version 1.0d R30 (4.99K) limited the current to ~1.65A. this is changed in revision 1.0e (3.33K) to raise the current limit to 2A. Version 1.0d assemblies can be patched to allow setting the increased current by soldering a 10K 0603 resistor in parallel (on top of) R30.
Heated bed maximum voltage
Motor Current
Pins
Fuses
Select the serial port: Tools > Serial Port, the serial port for Rambo is usually the last one.
Click to check if there is any mistake. If not, click to upload.
During the process of uploading, the 3 LEDs corresponding to TX, RX and L on mega board will blink, if the blink stops, the uploading is done.
After the uploading, you can go on with the next step. If the uploading is unsuccessful, read the error report on IDE, figure out the problem, and then try again. Some frequent errors are: a wrong select of board type and serial port.
Get Started
Rambo is the CPU of a 3d printer, manipulating the whole process of printing which can’t be put in use directly without uploading firmware.
#define BAUDRATE 250000
- define MOTHERBOARD 701
This parameter is set for board type. 3D Printer has many types of main board, and the setting of IOs is different, therefore, the parameter has to correspond to the type of your board, or it can’t operate normally. For other board, you can refer to the annotation on the board.
#define EXTRUDE_MINTEMP 170
FAQS
1. I can’t upload program for Rambo using a USB.
Check if the external power supply for logic part is plugged in, or if the power supply is ok.
2. How many extruders does Rambo support?
Rambo supports at most 2 extruders.
3. What should I do if the driver installation failed?
You may encounter a problem “system cannot find the specific folder” in the process of driver installation when you use starter edition windows, because the starter edition of windows system has deleted some uncommon information for driver. The resolutions are as follows,
A: open C:\windows\inf\setupapi.dev.log
The file not only includes plug and play device, information for driver installation, but also record the reason of the failure of driver installation. Open this file and move to the end of the file you will observe the following information.
"C:\Windows\System32\DriverStore\FileRepository\ "
According to this prompt, I created another folder with the same name in the path of “C:\Windows\System32\DriverStore\FileRepository\”, as follows,
C: Download and decompress the following file and add it to the created folder mdmcpq.inf_x86_neutral_********.
32bits windows:
mdmcpq.inf_x86.rar Media:(http://www.arduino.cn/forum.php?mod=attachment&aid=MTIzMHw2ZjJkZDY1OXwxNDA0NzAyMDgxfDY0MDF8MjQ4NQ==)
64bits windows
mdmcpq.inf_amd64.rar [[Media:(http://www.arduino.cn/forum.php?mod=attachment&aid=MTIzMXxkN2QxMzdiMHwxNDA0NzAyMDgxfDY0MDF8MjQ4NQ%3D%3D) ]]
Click Windows and R
Click “ok”
Click FAQ
Click advanced options
Click windows boot settings
Click reboot button
The system will reboot and go to the advanced boot options
After the restart of the system, you can install the driver and the installation method is the same with that of windows 7.
Files
RAMBo-manual:
RAMBo silk:
Click here to buy RAMBo V1.2a
